Thermo Electric
  • Thermo Electric
    Thermoelectric Battery
    If that 5 stack device can charge 1.5 volt storage batteries then each junction only has to produce 17 mV (5 x 18 junctions per stack)
    Digging further I found this pdf.
    This stuff is giving me ideas to experiment with combining the two effects. Generate current with the Seebeck junctions, send it back through Peltier junctions and use the produced heat and cold to reinforce the temperature differential of the Seebeck junctions. Maybe use solar heating during the day with heat storage (concrete/gravel) to rev it up and use the Peltier to help keep the heat & cold going at night & on cloudy days. A 24/7 Solar-Seebeck-Peltier generator.
    You know, .. this could be built on a shoe-string budget.
    Possibilities.
    Cadman
    thanks for "thinking" and sharing
    For heat storage water seems a win win [cheap "fluid"and available]
    Energy stored as sensible heat in different types of materials.
    just a side note .. in the news harvesting energy from temperature Delta ,here they play with Light radiation .[shared by member Exnihiloest [F6FLT ]
    The obvious drawback of solar panels is that they require sunlight to generate electricity. Some have observed that for a device on Earth facing space, which has a frigid temperature, the chilling outflow of energy from the device can be harvested using the same kind of optoelectronic physics we have used to harness solar energy. New work, in a recent issue of Applied Physics Letters, looks to provide a potential path to generating electricity like solar cells but that can power electronics at night.
    thanks for the topic
    Chet K
    BE that change !!
