[VIDEO]https://youtu.be/y-FA6Efh70k[/VIDEO]
Hi, I have been working on a TSO gravity assisted pulse motor to drive a 3 phase PMA. It is based on other designs I found on youtube. Basically it is a pendulum on one end of a seesaw. As the pendulum swings it will lift and lower a weight on the other end of the seesaw. 30 pounds on the pendulum and 110 pounds on the on the end of the seesaw. I plan to use a 3 by 3 Neo magnetic and a electromagnet that will be pulsed to swing the pendulum. The input force to drive the PMA is from the falling weight of the seesaw. The electromagnet will be pulsed at 12 volts 25 amps. I hoping for a 50 watts at the output. I will a be using a variable pulse width modulator at the output of the PMA to reduce the back EMF of the PMA. Suggestions welcome to determine the average power of the pulse used at the electromagnet.
cheers
