Thanks mbrownn. If I understand you correctly, I need to run 6 or more cycles of charge/discharge before I should be able to get more volts to charge than I lose from my source. If I can never get that, then I really don't have overunity, right?
I rewired one of the Conair fans with 28 awg wire. I first removed the small posts b/t the four coil posts. I could get more winds with the small posts out of the way. The one power coil is 350 turns. The other three coils are 324 turns each of #28. No bifolar. This gives me three times the turns/wire of trigger than power. The fan doesn't run as smooth. The magnets pull on the four posts. Now I know why those little posts were there.
I just finished it. My meter won't measure amps. Perhaps the spikes blew it out. A new(?) phenomenon I noticed is when I went to hook up the charge battery when the fan was running. I got sparks as I hooked it up. I never noticed this before.
I'm running a charge right now. However my charge and source battery are near fully charged already. I'll let it run for an hour then hook up one of my other fans to drain one of the batteries and do another charge.
