A wise man once said:
"so if you can't go home, and build a cold electricity circuit from old nylon records, aluminum foil, paperclips and magnets. IT'S NOT MY FAULT."
Okay so Peters lecture on EV gray and Tesla inspired me to go playing around with some high voltage stuff. I did not really follow the actual diagram by John Bedini because of lack of time and resources.
I don't have a motor
I don't have the high voltage end chopped, instead i do it on the primary of the flyback transformer.
I don't have capacitors that last more than 1 second.
But still the result is pretty cool, I can run a little neon bulb on the charge receiving grid.
Rough circuit:
And the movie:
YouTube - EV gray tube test 1
Problems:
If I attach a high current source (like a battery) the sparks will be much more powerful, but the mosfet seems to be unable to handle this, even with the heatsink it rapidly heats up.
I still don't understand the Diode that is in the original drawing, I'm talking about the one attached between the high voltage cathode and the battery. It seems to be blocking the high voltage from going to the battery. Can someone please explain?
I still want to add changes and gradually move to the original circuit. I take it step by step.
note: Don't pay attention to my messy and dangerous work environment. I have a very ad hoc way of working. Do not attempt to copy
Edit: added another video, cut the ground wire off, neon still burns dimly.... when I touch it it lights up :P
YouTube - EV gray tube test 2
enjoy!
Rough circuit:
And the movie:
Problems:
enjoy!
Is there any other way to make it work? Now I can't even think of any other use for it.
