oh this IS fun to watch you work on this particular motor because i bought one as well when i first saw it pop up on this disscusion group, but i shelved mine for now because that one will be my version4 motor and currently i am still working on my version3 motor (a 2 pole bifilar modified pressure washer motor). my intention is to master the control circuit on my ver3 motor and then apply that circuit 4 times to the 8 pole motor version4 motor
ok back to your work.
great! but it is still better not to do that, a better test is to dump the spike into diferent types of loads (batt, cap, filament lightbulb......) and watch how the motor behaves
anouther idea you could do that is simpler and less electronic is to control the transistor with a mechanical switch. you could drill some holes into the back of the spinning disk mounted on the back of the motor and screw a post that sticks out an inch or so and let that act as a cam to trigger a mechanical switch just like ben teal did. you just need to find a good push button switch that does not stay on when you first depress it! in fact, if the switch is a good say 15 to 30 amp switch you wouldnt even need the transistor. you could still keep the ne2 neo bulb accross the switch terminals to protect against arcing if you disconnect the kick back. other than that i am not sure if you would still need a spark snubber circuit for the switch or not maybe some one else here can answer that.
i am not familiar with the inner workings of an AC amp meter VS a DC amp meter. but in your video the one you are using to measure with is clearly an ac meter so i dont know if that is a very good reading or not. i would go ahead and just use the dc one you have there. i wouldnt bother to try and read amps on the kick back because that spike is comming back so fast and short that, while the analog is better than digital, it still will be to slow to respond and give you an accurate reading it will only be a lagged average.
i disagree, this is part of the basics and its one of the easiest to fix, first
run a test with your power supply set at 24v and measure rpms and amps
then remove the power supply and, i saw you allready have 2 batteries in one of your videos, just grab a third for the kick back and wire 2 of your wet cell batteries in series for 24v and make sure the motor runs the same. if it runs faster and the amp meter might go up. then your power supply is not supplying enough amperage and is current limmiting your motor. in the future you can always use the power supply to trickle charge your batts while you run the motor.
i would say now you are getting a bit beyond the basics. personally i found a solution that fixes this problem involving anouther reed switch but thats a tiny bit more advanced. i would recomend more thoroughly investigating the basic circuit posted at the end of lindemans dvd. in fact i would watch it again if you are asking this question (i cant count how many times i watched that dvd over the last couple of years!!) lets see if i can pose a question to get your mind going. after you watch the dvd again ask your self how many diferent duty cycles are you dealing with in the simple circuit? is there more than one? let me know what you think and hopefully i can help by sharing my answer.
hope that helps!!
Eric
hope that helps!!
Eric
! ). My transistor runs well and does not go out easy anymore.
