wow your tireless efforts just keep going. I had just bought the 5k pot..lol. excellent cant wait to build my own lunch box model.
The dual charging is a novel idea as well
One little question. It was not clear exactly HOW the oscillator and the rest of the circuit are connected. Thedude's original method was a parallel connection of the oscillator and a single ignition coil. Mart said he got his running with the oscillator running in series with the ignition coil. Currently, you say in your latest YouTube video that the "Bedini oscillator replaces the relay in the same position in the circuit". In your original LB unit, the relay was in series with the twin, parallel ignition coils. This implies that the relationship of the Bedini oscillator in your rebuild is a series connection as well. Is this correct?
completely silent. I like the way when you ground it you get the second bulb going with just your hand. Keep up the great work
I have did it both ways I have used the fan and the solid state and they both work pretty good.
i am learning fast and trying to change and covert as i go, I WILL NOT GIVE UP!! and try my best to help inform as i learn more
) if I connect it to the output diode and the + of the run battery. Im not 100% sure, but I think I had to install it backwards to the way I thought I had to. Meaning the negative of the cap was connected to the + of the battery. I will double check it, because one way the cap would fill but the light wouldnt come on and the other way the light would come on. More to come. Also think about another one of Johns circuits we could use to periodically dump that cap© 2007–2026 A & P Electronic Media and its licensors · posts © their authors · Copyright & Archive Policy
