I have two of the accel 8140's. I had to put both of them in parallel to get the energy out of my ssg. I have them running a cfl right now but i'm gonna hook it up to a cap soon and see what i can power with it. might even charge batteries. But i am running them with an earth ground to create an open system. The light on my cfl is nearly constant.
Single Wire Capacitor Charging
So when the cfl begins to glow only by touching the glass, its because I am grounding it via the glass? Hmmm. Have you noticed that the higher the frequency is the shorter the sparks will be, still it can instantly light up things like cfls and neons, and even charge a cap.
I wonder if the voltage can be magnified even more by connecting a flyback transformer to the output of the ignition coil
[/QUOTE]Originally posted by professor View PostAllcanadian
I have personal knowledge of a Farmer being taken to Court here in B.C. near Clinton he had strung several hundreds of feet of wire out on his Hayfield right under the High tension powerlines. He ended up in Court having to defend himself against the charges of theft of power laid against him by the then B.C. Hydro.
Sorry He lost!!!
professor
QUOTE=Allcanadian;30567]@amigo
Yes, this is a called a "net charge", if you google "electrostatics- net charge" you will have your answers to everything posted here. What should be noted however is that when a positively charged object is brought near a neutral conductor then one end of the conductor nearest the (+) charge will be charged negative and the other end of the conductor will be charged positive. This is not a net charge but a potential difference between the conductor ends, this potential difference requires a "current" to seperate as the movement of charge between a potential difference "IS" an electric current when charging or discharging. If the conductor is then connected to a source of electrons, ground or a metal plate then the conductor can be said to have a net negative charge. What is not readily apparent is the fact that a small current must be present when the conductor charges seperate and when the ground introduces electrons to the conductor. The conductor and the positively charged object can then be considered a capacitor because they will discharge into one another producing yet again---another electric current flow. That seems like quite a bit of current flow considering all you have done is to positively charge a single object or plate of a capacitor.
@All
There is much more here than meets the eye, what has not been considered is magnitude of charge. I have built the AV plug/cap circuit and can charge the cap to 1.5v in a minute or so from what some call RF energy. I have also charged 50/10uF caps from an AV plug diode grid these caps discharged in series produce a voltage of over 70 volts. The question I had to ask is --- is there any limitations to this technology? If fact there is no limit
If a person could build a miniturized capacitance with integrated AV plugs and 10,000 or more of these could be packed in a small area like integrated circuits often are then-- I will let you do the math. As to where the energy comes from, the burden of proof would not lie on me if I was accused of stealing power. Is it RF---from which frequency then and which station, If a power company says I am stealing power then the power company must be polluting my space with EM energy, energy I did not ask for nor want. Both parties are not stupid enough to open that can of worms as there are certain liabilities they must assume when doing so.
AC
So don't place your wire under a powerline?
All Canadian, it's been a while since your original post as quoted above. Have you tried your theory out in an experiment? Would you be willing to detail it so that others can try it for themselves?
Thanks in advance.
