Ralph Bergstresser| Device for Prolonging Ignition Spark | US Patent 3,939,814
  • Ralph Bergstresser| Device for Prolonging Ignition Spark | US Patent 3,939,814
    After talking to Peter a bit on the Kiker wires, he was telling me about Ralph Bergstresser and a spark prolonging device he used back in the 70's. Peter knew Bergstresser and Bergstresser had met with Tesla at sometime when he was younger. So here is the info:
    Patent: http://www.esmhome.org/library/ralph...S3939814A1.pdf
    AFTER I made a youtube vid on it, something made me look at the Kiker battery booster patent again and there you go...Bergstresser is the first cited reference. LOL. Seems things just flow together nicely here.
    Ralph Bergstresser | Spark Prolonger video
    YouTube - Ralph Bergstresser | Spark Prolonger | US 3,939,814
      Hi Aaron,
      Thx for all the good research your doing along with the other members in this forum .This sounds like a very interesting idea that literally anyone can try.
      -Gary
        spaced turns
        Thanks.
        It took about 15 minutes to wind. When I can get 22 gauge wire, I'm going to make another.
        I mention in the vid I would super glue the spaced turns. It was pointed out to me that I shouldn't super glue my spaced turns since it could eat the enamel. I'm going to use a hot glue gun.
          Production Model ??
          I found this when I was doing some searches on "coil-on-plug" devices, looks just like the patent -
          Power Booster Manufacturer exporting direct from Malaysia
          ::::STROMBERG:::: Official Website
          Stromberg (good spark plug arc shots)
          Could be wrong, I don't know ?
          Best Regards,
          Glen
          Last edited by FuzzyTomCat; 07-29-2008, 09:05 AM. Reason: added Stromberg web site
          Open Source Experimentalist
            Pipe threader
            Thanks.
            I know I am new here but I would suggest using a pipe threader on the tube. It should give you roughly the spacing you need with no need for any type of adhesive.
              Ralph Bergstresser Spark Prolonger US Patent 3939814
              I reposted this video:
              YouTube - Ralph Bergstresser Spark Prolonger 3939814
                Seen something like this B4 for older cars
                What a simple plan to enhance spark energy for each spark plug.
                Had a type of this on a vehicle years ago. This will only work on a coil sparked ignition system
                Acts 1:8
                  Thanks for finding this and sharing, Aaron. This is just what we need.
                  The loud bang I get when discharging my HV cap is converted to a quiet, expanded spark when I use a heavy series inductor, to provide a time constant. Bergstresser's coil takes a lot less wire.
                  This coil will allow me to advance my experiments. Ie, two caps, each with a different time constant. Reminds me of Pat. #3890548. Also, Keely was able to explode a drop of water - launching a cannon ball - by playing "C" "A" "F" on his violin. With A=440 Hz, higher harmonics can be calculated by multiplying the frequencies by any prime number.
                  Thanks also for the booster cap circuit!
                    I forgot to add that I'm discharging the cap through an inductive spark, similar to the CSET and the Water Sparkplug.
                    Webs.com has been shut down on the 31st of August 2023. Find out what that means for your site and how to move it to another provider.
                      Thanks for the info
                      I found something very similar on my last video, but connected to the negative of ignition coil...
                      YouTube - Inquorate 19
                        good idea for the first bit of the coil
                          Nice Aaron of course this will be interesting for those using the ignition coil for lighting purposes.
                          • #14
                            Really stupid question
                            Just a first thought, haven't read thru the patent, and can't view youtubes, my old 'puter can't handle it. If its just a coil, without an iron core, could I just take an ignition coil, and remove the core? Jim
                            • #15
                              Removing the core will allow the ignition coil to operate at higher frequencies. But that won't alter the discharge the way this coil does.
