tesla's radiant energy device ?
Y does this happen
Will put analogue gauge on the ampdraw and repeat the test. If the light go`s up and the draw go`s down we are on a winner.
The gauge on the negative of the bulbs will be removed and a cap will replace it.
What will be the results?
the draw will lower the light gets brighter the cap will charge and the charging batterys charges as it would normally.
the gauges issue is for pulse spike and im not looking for them im looking at the dirrection of flow!
What is happening, is this.
When lighting strikes, theres a ground leader going up first! the apmosfear charge is looking for path to go, the lower potensell in the ground pulls up the energy in the ground to meet it and Bang,lighting.
So the coil fires the energy gos in the bulb it would normally go to the less potensell of the negative on the battery But that is not connected so it looking for a path!
I give it a paths but with too many bulbs to go thought so it put from the less potensell,which can be a ground rod.
The energy gos up the rod thoght a cap to the bulbs.I get light and what is in the cap. Thank You Tesla Bebini Beardon Imhotep
sorry about the spellingLOL
RE: tesing..
I watched another video of someone doing similar they added more bulbs and the charging rate went up on the batteries. I look forward to see your testing results. The charging of the cap I think is the big deal can you put the cap in and monitor the difference as you change the frequency? if it is doing as the meter says you should see a big swing on the voltage in the cap.Originally posted by Bodkins View PostWill put analogue gauge on the ampdraw and repeat the test. If the light go`s up and the draw go`s down we are on a winner.
BTW for your spelling download the Google toolbar, it has spell check you can right click on words when you type in this forum, has saved me many an error.
Great work !!
See my experiments here...
YouTube - Bodkins Free Energy Radiant Oscillator part 2 no metersOriginally posted by theremart View PostI watched another video of someone doing similar they added more bulbs and the charging rate went up on the batteries. I look forward to see your testing results. The charging of the cap I think is the big deal can you put the cap in and monitor the difference as you change the frequency? if it is doing as the meter says you should see a big swing on the voltage in the cap.
Great work !!
Hi Bodkins,
I'd like to know if you're drawing any power from the charge battery from the Imhotep fan when you connect the cfl's.I'm asking this because I have ran a universal motor from the output of the SSG and found out that I was pulling power out of both the powering battery and the charging battery.I'm not exactly sure of your setup without seeing a schematic so hopefully you can post one soon.I like the idea of those cfl's running on 1 wire
.Thx for the videos and keep up the good work.
-Gary
I dont think these a problem in that area but will post soon to clean it upOriginally posted by gmeat View PostHi Bodkins,
-Gary
WARNING TO EVERYONE!!!!!!!!!!
Please dont connect to water pipes or tv cables or anything on the grid.
If we are pulling in the energy and there at short We are in trouble,Big trouble!!!!!!!!!!!
i have seen small sparke for the ground to the light connection if i had this connected to pipes Nightmmare!!!!
Think about sparkes in the pipes GAS PIPES!!!!!!!
BANG!!!!!!!
