Roter Less Pulse motor
  • #16
    Originally posted by byjoveoldchap View Post
    This is a superb document patmac
    Just by reading the first few lines, I can 'feel' this guy is going to teach us a great deal about capturing Radiant Energy!
    Thank you for sharing this. Can you offer more help on Ossie Callananat all?
    REAC Ossie Callanan Reed switch ocillating
    Hes a Star
    That book looks Ace the price was crazy we need that info
    • #17
      Originally posted by slayer007 View Post
      No try it that way.
      It takes more power and the light wont be as bright but it charges alot faster.
      What about the copperdiode?
      You tryed it? I(tesla) have a idea on this setup that may chance the world
      • #18
        Rare Working Crookes Heating Effect Tube
        Originally posted by Bodkins View Post
        I used a REAC Ossie Callanan Reed switch ocillating bedini setup about 4 months ago will dig it out and share info when i can.
        Hes a Star
        hmmm, I think you'll find this interesting as well then:
        "...contains a square of platinum foil which glows red hot from the impact of focused electrons when the tube is activated by high voltage from an induction coil."
        "I say that if a TEN year old can do this and win, what the **** is wrong with the whole World?"
        ~ John Bedini ~ 8 Mar 2000 - http://www.keelynet.com/bedmot/bedmot.htm
        • #19
          thanks byjoveoldchap
          patmac sorry did not see the link
          • #20
            Bodkins
            I've opened a thread about the modification Ossie's Callanan design.
            I created that thread because this thread is about Rotor-Less, so I don't confuse the good slayer's idea (rotorless), too I want follow the rules.
            Steve Jobs. Apple CEO
            • #21
              slayer007 -- 2nd circuit--My replication
              Here is another diagram of the circuit.
              In this one I show how I charge up another battery.
              Note the negative going from the capasitor to the negative source battery.
              I think it charges much faster this way but it takes more power and light wont be as bright.
              Without the ground it still charges just not as fast but you get a nice bright light.
              Well here it is. It works as advertised. Just like you said Slayer. Well done. I find this a facinating circuit. You can play around with it and does different things depending on what you want it to do. I put two reed switches together ( a tip from Mart Hale who put two relay chargers together to keep them from sticking ) and that really helped. I then put them on top of the coil like Ossie did and that helped more. They make a hissing sound when it is running. A small Neo taped to the front of the coil in the right spot keeps it in self oscillation.
              YouTube - Slayer007 ---2nd Circuit-- Rotor Less Pulse Motor
              Lidmotor
              • #22
                Lidmotor
                Thank you Lidmotor for making your second video.
                Another Great video.
                Allso try putting your diode right off the transistor.
                That way when you unhook the the ignition coil you can still recover the BEMF off the primary coil.
                I allso tried useing three bifilar coils in series with the second windings going to a recifier just like with the one coil.
                This actually made my amp draw go down and gave a little extra power.
                The best I could get so far was to charge a battery and only use about 60 mill amps.
