Originally posted by Spokane1
My take on this:
You can extract energy out of the electric field itself, which is an energy source as shown by Prof. Turtur and also explained by Bearden, no doubt about that.
What you need to do is use the electric field (voltage) generated by an oscillator to get a coil into resonance at a multiple of it's half wave resonance frequancy, in such a way that any disturbances created by using the power of the resonance (f.e. in a transformer) do not end up in your oscillator. The easiest way to do that is to use a modulated HF oscillator, where the "audio in" to the modulator corresponds to the half wave resonance frequency of the coil you want to drive into resonance. Most likely you need a high pass filter to make sure the LF disturbances created by the load into the coil cannot reach your oscillator.
That, IMHO, is really all there is to it. A full open coil resonating in half (or full wave) resonance has high voltage, zero current at the terminals. So, you can drive a coil into this specific resonance mode using high voltage, zero current using a capacitive coupling to your oscillator, which also forms a high pass filter.
So, IMHO, the CSET is basically a HF spark gap oscillator, even though in my article I may have missed some details about how this should be operating. I have a feeling I am really close, but not completely there yet. Something is itching, but I don't know what exactly.
And all this is based on a comparison of Gray, Meyer and Puharich, which IMHO are all variations of the same concept.
Arend Lammertink, MSc.
What you are seeing is a normal reaction for a neon bulb. Neon gas glows when it is energized by a voltage of around 70 volts depending on the spacing of the electrodes. If the voltage is very close to that voltage then the extra energy from any kind of light will push it over the edge and cause it to glow. What you have discovered is what causes lasers to work. When the laser gas mixture in an industrial laser is energized it starts to glow. As the light is reflected from one end of the laser tube to the other the light causes the gas mixture to produce more light which then produces more light like a chain reaction. Hope this helps.
