Btw the north monopole is positively charged which makes it a replica of the Gray tube - or the inverse... Anyway, progress.
Gray Tube Replication
Why is earth negatively charged(Answer: neutrinos(aether units) that convert into electrons!):
"If gravity really is a flow of aethers of some voluminosity, towards mass, how can mass accumulate this voluminous aether, while it empirically seems to disappear into nothing."
[R. N. Boyd]: The problem is easily resolved by the realization of the fact that, as the aether flux becomes subluminal, because it is slowed down by interactions with "normal matter", it will "self-organize" to become electrons. This sequence of the creation of electrons from aether fluxes, ab initio, was actually demonstrated experimentally by Nikola Tesla in the 1920s. Tesla obtained massive electrical power this way, quite by accident, as he was attempting to find the proper numbers of power pulses per second which would couple into the interstellar aether flux at resonance with the Earth's aether resonance rate. Tesla found that his Earth-pumping magnifying transmitters would operate at peak efficiencies, only when specific rates of pulsations were applied. He also noticed that the timing of the applied pulsations could produce either zero readings, or maximum readings of power, on the output side of his system.
This caused him to realize that there were incoming aether flux "waves" that were arriving with unfailing regularity. He realized that the instances where he had obtained zero output readings were those cases where his applied pulses were 180 degrees out of phase with the incoming aether waves, and of course, strongest when the pulses were applied in-phase with the incoming flux peaks. This situation provided evidence that aether flux from interstellar space is not a constant and smooth value, but varies with time. He realized that the Earth, as a massive whole, was modulating parts of the aether flux. He discovered a large number of various periodicities within the aether fluxes. He found the sources of all these various flux rates had several causes.
Space-sourced aether pulses entered the Earth at rates apparently related to mysterious processes occurring in the deepest reaches of outer space. Many such interstellar processes generated pulsations having nothing to do with Earth. Other rates had to do with processes in space we may never fully understand, representative of the properties of the interstellar medium itself. Yet, there existed a class of pulse rates definitely related to the nearby sun and to the Earth as a resistive mass. Tesla found that the Earth's rocky crust represented a resistance to the otherwise smooth passage of aether flux pulsations through interstellar space.
Tesla found that the resistance of the Earth's crust to the passage of aether, caused a local intensification of the aether flux to occur. He observed that a self-magnifying, self-collimating, property occurred when the aether fluxes encountered the massive body of the planet.
The so-resisted aether then self-focused into the locally resistive medium comprising the planet, resulting in locally intense aether flux bombardments in the resistive media, resulting in locally explosive emissions of showers of subatomic particles. One of the principle emissions was numbers of electrons. It appeared that electrons would spontaneously appear in the matter of the planetary body due to such resistivity to the aether flux. The resulting electrons acted as an aether "contaminant" which would choke off the normally smooth and unencumbered aether flows. In other words, the process of the conversion of aether particles, into electrons, due to the resistivity of the Earth's crust, acted to further retard the aether flows, in addition to the resistances inherent in the materials of the Earth's crust.
On the terrestrial scale, the results of these processes were observed to be enormous in scope. Tesla found, for example, that these processes were responsible for the molten core of the planet, and for the constant excesses of electrons which give the planet a constant net negative charge. Tesla also found a direct correlation between the local aether resistivity of the earth's crust and the local rate of lightning discharges, in certain areas which were already notable for locally prodigious lightning activities. And so on...
Anyway, when the proper pulse rates were found, Tesla had gigawatts of electricity to deal with in his Magnifying Transmitter equipment, rather unexpectedly. Fortunately, no one was hurt.
On the other side of the same coin, explosive discharges of electricity, approaching the ideal of the Dirac delta function, cause the dissociation of electrons into their component aether particles, which then stream away from the discharge site in superluminal ever-expanding shells. Similar processes are probably occurring all the time in the bodies of the stars, resulting in aether emanations from the various stellar bodies. It is possible that localized processes can also occur in interstellar space, which can also result in aether fluxes. Interstellar space is not at all a perfect vacuum.
Ok, so here I continue my monologue(any comments are welcome..)...
Earth is a mirror image of the Gray/Meyer circuits when making electrons(and protons). Earth has positive core, positive ionosphere and an electron generator at the collisoion site between the E-fields from ionosphere and core. The E-fields meet at the crust - BOOM, we get materia and negative current(electrons from neutrinos/aether units converting where the E-fields meet) which make the crust grow year by year.
Anyone sees the importance of this??! Only thing remaining to figure out is how protons are created(positive-positive makes electrons, how about protons?) to make the balance complete. Day and night balance should give us the answer.. Look at the magnetosphere during daytime and night time..
The cold current receiver hence should be constructed like the earth with a spherical geometry(conducting core(+), dielectric(HHO?), thin conductor(crust), dielectric(atmosphere) and thin conductor(ionosphere)). Rotation is the final twist to aether reception balance I believe.
So the beads are simple to realize now.. Just mirror image the planet for electrons and proton generation(cold fusion is proton generation). Remember magnetocurrent are either imploding(proton creation) or expanding(electron creation).
This is getting VERY CLOSE I believe, anyone cares to feedback?
Gauss,
I'm trying to follow you
but I can't find what is scroll wave . Can you explain ?
I would understand better but due to lack of education I must study Maxwell before
There is something in it... Can you compute Meyl equations for the case of stationary AC longitudinal waves on secondary transformer wire ? What remains ? Tesla described it as white misty non -electric flame , several inches long.
Would it be a magnetocurrent ????
Gauss,
I think I get it.
But could ya upload a diagram So's I can See It . That is if it is buildable. The use of spheres instead of cylindrical electrodes sounds interesting
but It has to be a reality to build, and work with the intended purpose that Greys tube is supposedly designed to do.
big cap and carbon resistor
Hi Mr. Sherlock,Originally posted by Mr. Sherlock View PostHi everyone,
I am new here. I am building a Gray tube and in need of two 12uF 7-10kV capacitors. I have all the rest of the materials lined up.
Can anyone point me to where I can buy these (cheaply)?
Thanks.
I see good deals for caps that big on ebay once in a while.
What are you using for a carbon resistor?Sincerely,
I found a 16uF cap, at 7.5kV, in a junk defibrillator which came out of a dumpster behind a used medical equipment store. There was also a bunch of other hV stuff. Switches, vacuum relays, diodes, a transformer, etc. The only thing burnt out was the hV slide switch.
I went in and talked to the guy, and he said that the general public can only buy non-working equipment. So he sold me another defibrillator for $25. This was a newer, smaller type. The cap is only 5kV, but it's 46uF. And the kiloVac DPDT relay has a 12V coil.
@Aaron
I've been looking on eBay for some time now. I don't find any that size. I'll keep looking...
For the carbon, I took a "D" size battery, opened it up and took out the graphite rode from the positive terminal. Cleanded it up, cut it into 3/4", 1/2" pieces with my dimond blade wet saw and made a 1/4" hole on to each end on my lathe for press fitting my LV stainless steal rod.
@Elecrtotek
Thanks, I wish I should be as lucky and find some the way you did.
Thanks guys.
@Gauss
I bought my diodes from them but they dont have that particular cap. I thought of buying two of the 24uF 5.2kv caps they have and connect them in series. That would give me about 12 uF at 10.4kV wich is close enough, but it will cost me $600 for the 4 I have to buy in order to make 2 of what I need.
That price is way over my head. If I could knock of a zero from that price, I'd be happy.
Thanks for the info though.Last edited by Mr. Sherlock; 12-19-2008, 02:24 PM.
I don't think a big caps are required.Anyway you could easily build smaller one yourself for no more then 20$. Investigate Tesla patents.Use SS plates (cheap China plates) and container filled with boiled oil. Of course that wouldn't be 10 uF
