Rei's circuit
Rei,
The tube isn't necessary to make it work; it just makes it stronger.
If you make the "grid" point closer to the HV source than it is to the LV point, when caps are charged, the HV will be forced to hit that first before going to the LV point. For example, it may even work if you have the grid point directly in between the HV and LV point...then the HV point can't not hit the grid (capacitors) before going to LV point.
I would keep the LV rod totally disconnected....leave the HV source running and charge the cap to the "grid" point....and when the caps are up in voltage, use a wooden stick or whatever to connect the LV side to the ground...like a single shot event. I'd remove the diodes and battery as well and just make a straight switch connection from LV point to the ground.
Rei,
