Radiant Matter
  • #31
    then that would mean amp flow wouldnt it ?
    Maybe if you read the info that I am talking about you would get a better idea . If you dont remember where that was i``m certainly not gonna tell you ..
    • #32
      Mr positive serve all, share all, we all win.
      • #33
        The electric motor and generator would never have been discovered if a dielectric (insulation) had not been discovered. If one discovers a dielectric valve for the energy of the universe, one has the answer to harnessing the energy of the universe! A limiting case of excitation is ionization, wherein energy is absorbed by the atom sufficiently to allow a loosely bound electron to leave the atom, against the electrostatic forces which tend to hold it within the atom. An atom which has given up one or more electrons is said to be ionized. It is possible that ionization, i.e., excitation, may take place in successive steps through absorption of quanta energy. The return of an ionized atom to a state of lower energy is associated with electromagnetic radiation. Also, from the process of ionization, electrical energy may become associated with the vibrational forces of the universe coming into the earth as cosmic radiation. The higher the frequency, the greater the ionization or excitation, a form of energy which is kinetic in nature. There are tremendous energies coming to the earth from outer space. These energies are only different manifestations of the energies we see in operation all around us. In most cases we are not even aware of their existence. "They penetrate everything including our own bodies. Every one of us is alive by virtue of these energies. Every part and particle of the universe is alive with them. The generators that now furnish our electric power do not create or originate any power or electricity; they merely direct, pump, the existing energy or electricity
        • #34
          Funny lol
          Hey i was just wondering lets say that the negative plate is producing radiant energy at a high velocity but it was also possible for radiant energy to travel at a low velocity how then would it be possible once the radiant matter has left the low velocity source to cause it to accelerate.
          As well lets say there was some kind of signal in these radiant transmisions would it be possible to create radiant power amplifier.
          I was just wondering if there is a relationship between chi and radiant matter and that a psi wheel rotates due to radiant matter pretty much the same as in Crookes experiment. It would be interesting to listen in on the radiant transmision as the particles flows out wards. Would there be a way of doing that as well. You would then be able to test chi and correct it in unhealthy bodies. What yah reckon
          Originally posted by Bodkins View Post
          pontential difference is the point once you have that it gets interesting
          • #35
            Low Velocity
            Just had a thought if chi is generally found at a low velocity and it is radiant matter then then would mean that speed hos nothing to do with radiant matter production. That would mean the vital point is the undirection nature translated to humans this would mean certainty. The pulse width frequency changes its nature. I would assume the pulse width is like a bundle of this radiant matter. How then would i test if chi is radiant matter at a low velocity. Were the glowing nature of the rubies in the chamber reliant on high speed radiant matter. I would really like to work on this as i am a bit of chi fanatic if i could just electrically quantify its nature i would be extremely happy. Of course there is the chi/psi wheel but i would like to find other correlations between chi and radiant matter.
            • #36
              Potential difference
              On when you say potential difference do you mean charge density of a staticly charged dipoles
              • #37
                I do hope you going to do the star of david experiment dmonarch,
                Im off bed to sleep after a week on night at the hospital in the uk.The good thing is your last coment will run around my head till sleep pull me under.
                • #38
                  Energy of the univserse
                  That is so true. I think i see what they mean by splitting the positive. A conductor contains free electrons dosnt it. Lets say you have a hv hooked up to two plates but without a discharge which is very important. The left side is postive and the right side is negative. By having a diode on the postive side you ensure the unidirectional nature of the pulse. As well by having a diode which goes from the negative side to the positive side your essentially creating a charge pump which sucks all the charge from the negative plate and wire into the positive side. Now you have a conductor which is electron free except for the bound unless i guess the voltage was great enough. The negative side now is dialectric metal. Is that right
                  • #39
                    Star of david
                    Excellent. Yeah i will do it. and i figured out the setup as well. I will just get a start pastry cutter. Place a piece of metal on the bottom and clamp it to the start to create a container. Pour the wax mixture in place a piece of rounded metal in the middle of the star on top and apply the HV until it cools. It would be super nice if i could find a plastic cook cutter that would stand the heat of the melted wax.
                    • #40
                      is it affected by the law of gas pressure? I dont now much about chi teach me!
                      • #41
                        Im going to do a video about lighting when i can on how i see what is happening in layman term but i think you have it!!!
                        Im visual person.
                        I do like our little thread
                        one video for you YouTube - Bodkins 35 diode ground.AVI
                        its all about the diode
                        • #42
                          @ dmonarch
                          Maybe chi is not slow moving aether waves, but a dynamic / flowing movement of standing aether waves? Matter is just standing waves of aether, virtual particles are the resulting nodes of aetheric compression resonating with the particle itself. So why can't chi be a standing wave expression of biological energy?
                          • #43
                            Chi
                            I dont know anything about tai chi or anything formal like others do i simply no the effects and what i feels like. It is ironic though that we all produce it to some degree or another. How it is produced that is the circumstances tends to dictate the effect.
                            I will start with a situation which is common. You know how your sitting listening some great music of watching some dancing and for a moment seems especially beutiful and suddenly woosh a wave energy that feels like a gas around you skin just shoots up your body for most there hears stick out. I alopecia so i dont notice that any more. This uncontrolled chi, enjoyable and beutiful still.
                            I remember the first ocult book read was by aleister crowley which said the key to magic is passion. What i have just described is how most people experience that passion.Now what you got to do is connect with something that you are passionate about and purposly cause that wave event. For me i connect the idea of god/creation/the whole universe perfect sought of things. I dont imagine an image is just and idea to get the emotions going.
                            Once youve got that you'll notice that it dosnt have shoot up from the bottom of your body to your head and that you can move it where you want. Once remember what it feels like you can cause it to occur without any thoughts or ideas just the idea of it appearing and moving. I guess its allot like genitals in that you dont need stimulation physically and idea will just do.
                            If pushed out hard its like a baloon around your body. If hard like this you can feel it pushing between your skin and the sheets when in bed. In this form it will not travel through matarials its just to dense. The radius to which you can make the balloon increase over time. If pushed into a specific part of your body is produces a muscle spasm upon the fluid being condensed to the maxium. So condensing it creates a local electrical event. It is very different froma normal muscle spasm in that it seem to suck the msucles in.
                            That was when it is dense. FOr this part you dont need to create such a pasionate event or moment it more like steam rising from the skin. When its like steam there seems to two things going. One the steam thing which just rises from the skin. In this form you can push it with your hand which is really neet. It means you can condense it into your hand by moving the right hand up your left up towards you hand. In the steam form you can feel it just by putting your hand up the area as well you can pass steam from your hand to any area. Sometimes one area might be a bit sluggish so just pass the steam there. None of this involve imagination or anything it does require that you sought of be in the moment. By being in the moment none of your past ideas dictate you and so will not ruin the likelyhood of feeling it. Being in the moment is kind of like the equivalent of being unidirectional when it comes to radiant energy. You can actually slow it down even more which feels like individual atom size electric shocks. Its like one atom of radiant matter coming out at a time over the area of your arm. It hurts like an shock.
                            Hope this helps. If you want to know more dont hesitate to ask
                            • #44
                              Chi and waves
                              When chi is in the steam form you can cause it to wave. This is what you do if you want to decouple you mind or spirit from your body. When you begin playing with the energy and get to the stage of producing steam thats allot of fun. Once again to make the steam wave just recall what wave water or a flag would be like. Not imagine it just move through time with a wave
                              • #45
                                Nice
                                Nice video man i need to really get a camera. Just purchase a bench supply and function gen. Now i got someone to talk about this stuff too experimentation is in order.
                                I was just trying to create a mono pole charged capacitor but it is useless trying to do so with a symetric cap. Every time you try to do one thing with one charge the other comes in nosies. .
                                Hey what do you reckon about making monopole torroidal rings. Think its possible. I mean just read how simply it is to create an air version. Maybe you could get a the same can with board and bottom and top charge the can positivly and and tap the bottom. Thats not quite right i know but how you reckon would do it.
                                Im visual person.
