Aromaz Radiant Energy Joint Research Group
  • Interesting site
    Haven't checked all the references and page links yet, but interesting So far
    Physics - Aether
    • 4th dimension nonsense
      I don't think a 4th dimension is necessary to explain charre, etc as above page suggests. Because voltage polarity is due to actual potential difference, free electrons travelling up into sky as lightning, and pos nuclear particles travelling down as gravity - is not subject to perspective. No need for 4th dimension to differentiate between someone looking up and seeing clockwise spin around verticle axis, and someone looking down and seeing anticlockwise rotation around verticle axis - as up and down are a result of gravitational force resulting from and causing up/down difference.
      • Aromaz / Joit
        You guys may like this
        Physics - Matter
        • about 4th dimension
          I think all still have to abide the same physics. The difference is made by different speed of level.
          Our world > Molecule > atom > ether > aether.
          Lower level has higher speed, higher frequency, higher energy.
          Maybe we can tap ether energy with MHz resonance.
          • "If you can not conquer your enemy, then join them by
            making yourself appear to be one of them; while you use their proviand to
            prepare yourself for battle - from within"
            • Last edited by Aromaz; 01-31-2009, 12:16 PM.
              • Video sharing
                I will cut and post videos soonest I have some reasonable
                equipment to show measurements. Unfortunatley I will most
                likely have to build them myself, fortunately there are some
                ideas and contraption designs floating around the ether.
                More help in this matter will also be appreciated.
                • Corrie
                  More practical help - hope to be back on board experimentally in the next week or so. Was going to buy Oscilloscope this week, but fridge died in this 35 + degree heat.
                  Anyhoo, more reading, this one not so much 'theory' but closer to 'method'.
                  Genesis of Free Power Generation
                  more from me soon. Fingers crossed.
                  • Lenz's law
                    Hey, if we practically cancel out magnetic field in a coil by making Bifiliar pancake coil, and the magnetic field is not there to resist change in magnetic current, will the voltage then only rise at instant of switch closure due to electron bunching effect? And can we energize another coil with this voltage, (not Bifiliar winding of same coil)
                    Subtle twist on the tesla coil? 1 to 1 ratio..
                      Hey, if we practically cancel out magnetic field in a coil by making Bifiliar pancake coil, and the magnetic field is not there to resist change in magnetic current, will the voltage then only rise at instant of switch closure due to electron bunching effect? And can we energize another coil with this voltage, (not Bifiliar winding of same coil) Subtle twist on the tesla coil? 1 to 1 ratio..
                      I am not sure how you will be able to affect another coil if there is no magnetic field?
                      Though there is something in the far back of my mind of a gent in the 1840's that generated electric charge with two coils connected like this; not to have actual current flowing. I seemed to be more of a ping-pong game with some energy taped off for whatever he could use it on - that was way before Tesla or Edison. What did they use electricity for in 1840's ????
                      Dr Tewari (Prof in nuclear physics, physics and maths with very broad spectrum of knowledge) - probably can say genius - doing great leaps into alternative energy research. He has the resources, students, manpower - and the Indian government behind him - with very big financial support from both government and private sectors. I followed a series of 32 hours video from him in December. I have very big respect for him. Best still: He is not only doing theory, but he also design and execute many experiments to verify his theory. What you describe above i9s very much what Dr. Tawari did with his Space Power Generator.
                      Here is one of his other sites: Wind Energy, views on fossil fuel and nuclear energy
                      • Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
                        • Comment
                          • Um, guys..
                            I've been off doing homework set by dr lindemann in my 'beating Lenz's law' thread.
                            WOW
                            I recommend reading the thread to all those following this one.
                            especially read chap 8 and 7 by tewari here
                            The Home of Primordial Energy - THE Place for information from BRUCE DePALMA
                            The trick; electrons / positrons. That's it... Oh, and did I mention we can make new electrons?
                            Magnetic fields are concentrated time fields.
                            Etc...... Well worth reading, it's a very useable theory.
                            • @Inquorate;
                              The De Palma machine has been resconstructed by number of people, to the
                              exact details available and with variations. Nobody else to this date could
                              get it to even work economically. I do not say that it can not be done; but ?
                              • @DavidE
                                Personally I do believe that the ultimate answer is going to be in manipulation
                                of magnetic flux in combination with manipulation of electrons. Each of the
                                people who did had some success in this field, had their own ideas.
                                Strangely enough that none of them are the same as another.
