Aromaz Radiant Energy Joint Research Group
  • #31
    A couple thing I observe during experimentation using Imhotep Radiant Oscillator, lite version with relay without neon without battery first picture:
    - Amp can be detected at collapse point using positive probe only
    - Voltage can be detected at battery positive using negative probe only
    My opinion:
    There is radiant energy caused by back EMF which make the collapsing point has more energy, create reverse polarity between collapse point and battery positive. Without alternative path other than current coil to go (which still have stream queue in line for a brief moment), it will radiate to sorrounding. And because of that the point at battery positive will try to compensate by making more negative polarity than sorrounding.
    Added coil with lower resistance than the relay coil (1/10 of it), second picture:
    - without battery or neon, the relay noticably slowed down, stutter as though it get voltage while switch is not at normally on position. Notice that there is no diode or capasitor in the circuit.
    My opinion:
    The back EMF by new coil is bigger than back EMF by relay coil. The bigger EMF will force to go trough the relay coil, resulting to relay being activated again and prevent the switch reverting to normally on position. When load is added, the back EMF generated by both coil will prefer to go trough the load if load resistance is lower than relay coil, less back EMF will try to go trough relay coil.
    In solid state version, since it is known that diode can not prevent back EMF from propagating, the back EMF will go trough the transistor too, going trough the circuit to make the shortest/fastest close loop. If resistance (or inductance?) is lower at charging part, the back EMF will go trough thr charging part, the opposite is also true.
    • #32
      what's going on here?
      Some interesting oddities to share
      YouTube - Inquorate 21
      • #33
        You sly devil you .. you built a detector.
        Something that's going to remain constant!
        Anita Ward - Ring My Bell (1979)
        At what distance does it start to light up
        (got a yard stick or broom stick) and
        then does it stay lit in a 360 degree circle around the
        circuit, High and low too. A weakness at some point
        could indicate some directionality or void in something.
        Randy
        • #34
          direction and strength radiant energy detector
          @ vortex - you're right, it's a radiant energy detector, direction and strength. My relay surprised me by being a stronger source of it than the coil, or at least in the direction I 'looked' in... Gotta be up early for work.. :-(
          Everyone's gonna want one of these!
          It'll help identify what is a good transmitter of radiant energy, where it leaks from, what it goes thru, etc......
          And it costs about a dollar :-)
          YouTube - Inquorate 22
          • #35
            Neons
            Here's where I got the neon, anyone got any idea how it's working?
            Jaycar Electronics
            • #36
              A little quiet
              @Inquorate; Looks very amazing! I will try to duplicate this very soon.
              Will also copy your other data from Luc's when I have bit more time.
              @All: I am am around and do keep an eye;
              - My computer is fully occupied with downloading lots of info at present,
              so I a can not do too much for next day or two. Today downloaded 18 hrs
              of assorted videos - just about transistors and in particular the 2222!
              Guess what are my bedtime stories on TV/VDO ?
              - I am busy preparing demo's for my friends and investors due on Monday.
              Thus I will be a little quiet for next few days.
              • #37
                Excellent idea!!
                Aromaz, thank you for making this thread and taking the initiative to get something of a formalized group effort going! I think this could be an important step in the right direction.
                I have been consistently impressed with your prolific and successful reproductions and development of new circuits, and my congratulations on your several successes! You and the many other Free Energy inventors, experimenters, and hobbyists here and at the other FE - Open Source Energy forum sites are doing Humankind an important and desperately needed service.
                Although i may be a "forum ghost" currently when it comes to doing the actual "wet work" needed for Free Energy experimentation (hopefully this will change in 2009 ); i would offer my services in any other way i could to help in this great endeavor. This could include doing web research, fact checking, helping to design Test Plans, or simply recording it for posterity
                • #38
                  Dielectric Refraction
                  When Radiant Energy passes through a curved dielectric, it leaves the far surface at a perpendicular angle, regardless of the angle of incidence on the inner surface.
                  • #39
                    @ Electrotek
                    Interesting. How'd you figure that out? If you've details on any experiments I'd be interested in duplicating your efforts :-) someone on gray tube thread said that radiant energy will travel along straight lines and right angles, so I don't doubt your claim, esp as my 'detector' shows radiant energy coming out of the system like a gas, or liquid. And when there's a hole in a garden hose, keeping the hose straight will somewhat plug the hole, bending it will cause the hole to leak at a right angle regardless of the curvature :-)
                    • #40
                      @Inquorate:
                      The ancient symbol called the Mandala depicts this effect, as do some crop circles. Also relevant is the Cliff Castle crop circle. (Sorry I don't have any links at the moment.)
                      Your garden hose analogy is interesting.
                      What kind of detector do you have? I haven't had time to download the video yet. Is it that curtain clip thing you have in your avatar?
                      • #41
                        Water Affinity
                        Here's another one:
                        Radiant Energy has an affinity with water. Water can carry this energy into a substance. Then, when the water evaporates, the energy remains as interstitial energy. This is why dirt clods.
                        This came from The Cosmic Forces of Mu (Lemuria), by James Churchward. This civilization predated Atlantis by several thousand years.
                        • #42
                          Mu
                          Mu was in australia. I've often thought atlantis used tesla technology and gave anti-gravity to egyptians.
                          @ Electrotek have you read 'the biggest secret' by david icke? I sent bodkins a copy as pdf. My computer is dead but he may email it to you?
                          You'd be surprised how far our history goes..
                          • #43
                            Detector
                            A bell, a neon, and alligator clip taped on a thin bamboo rod..
                            • #44
                              Funny, One of the tidbits I have read regarding the SG circuit is to place the output diode @ 90 degrees. Hmmm
                              • #45
                                Some Experiments
                                Some of my experiments are depicted in the picture I'm using for my avatar:
                                Jerry's Site - Artifacts
                                The primary effect is at the bottom left of the silver sphere. You have to enlarge this area several times in order to see it clearly. At this point, the energy shining through the copper band doesn't appear to be refracted, hence my conclusion that it is a dielectric which produces the perpendicular refraction. And the notch in the copper strip is actually on the back side - this part of the image is triple rotated by the optical gradient.
                                Dark Energy is also visible in several places in this picture. I scanned this image from a Polaroid Print, and I can see every detail in the original picture, using a microscope. None of this is a digital artifact produced by the scan. At the upper left corner of the picture, there's a shadow over a dip in the pavement. This leads me to think that the Dark Field resonates across a depression in a surface, something which is consistent with various Scalar artifacts and tools from the ancient times.
                                "In the beginning, darkness was on the face of the deep."
                                I think Dark Energy is an interesting subject. But it can be used for EVIL (Energy Vibrating In Light). So I won't go there at this time. However, I will point out that there's only one shadow on the curved end of the left hand Resmod's central electrode. The dark part at the end is a piece of heat shrink tubing. This produces a region of higher dielectric constant, resulting in the same effect caused by the top ball capacitance of a Caduceus. (I'm talking about the Caduceus as the actual ancient artifact, something the 'ancients among us' refer to as "the ultimate force commander", since it generates seven different forces.) I believe this type of Resmod was used to build the Great Pyramid, since it's depicted at Ed Leedskalnin's Coral Castle, as well as in the hieroglyphics.
                                My picture also shows a CSET I made from a beer can.
                                And I have a few other pictures related to this one, including my cat looking at part of a large circle of energy going out into the surrounding area.
