Originally posted by Guruji
Guruji. if it's not working at all you might have your coil wired wrong.
Or I should say the wires comming off your coil might be wired in the wrong way.
Did you notice there should be a dot or a letter by one end of the coils in the circuit.
The dot should be the beginning of the coil the other side with no dot is the end.
You will notice the beginning of one coil will go with the end of the other coil.
So coil 1 with the dot should go to positive of the battery.
Then coil 2 with no dot should go to the positive also.
Coil 2 is the one that should have the 1K resistor on it.
I hope that will help I don't know if I explained to well.
EDIT.
Thanks for showing your circuit Tectalabyss it looks interesting.
I had to use normal wires.
Cheers,
