Panacea-BOCAF 2nd MRA replication -COP =8
  • Panacea-BOCAF 2nd MRA replication -COP =8
    Guys, as soon as we find some off the shelf parts for a rep, lets send one to our commanders and chiefs, Aaron and Peter. They can help keep it open source and improve it
    This one has got more info and data to support Norm and Joel's patent
    suppression case, as well as a nice COP of 8. If you are able to
    contribute to helping this situation please contact us.
    Hi guys,
    Nice work !
    Can we say that Luc's simple LC resonant circuit demonstration, lighting a neon bulb from the 1 Volt of the frequency generator is on the same concept than the MRA ?
    If not, what are the main differencies ?
    Thanks to enlight us with this system,
    and good luck,
    MDG.
      Um
      what's an MRA?
      Did I miss something?
        Oh ok
        Just borrowed a friend's computer (phone won't display google videos)
        And now I get it... Gotoluc's circuit, or very similar..
        Looks cool
          magnetic resonance amplifer. Essentially all about resonance, and why not...its the mother and father of free energy.
            Ash, this looks good, but to get the final proof I suggest an experiment for you. Measure the exact resonant frequency, then build a simple 555 timer that outputs a 50:50 square wave at that frequency and power the circuit from some high farad capacitors (for example those from car audio systems). Then hook the output to some other capacitors of that size. If there is truly a COP that great, then you should be able to charge up at least two such capacitors on the output with an input of only one cap.
            Thanks!
              Jetisjs
              I agree with you, build OU system to use energy directly is more complex, so is esier add time to the potential, the device that allow us do it, is the capacitor. We've remember that ideal capacitor is charged only with potential, but real capacitor use current because the plates moves and this generates losses, this explains why Bearden recommends super rigid plates capacitors, this avoid the looses where applies newton's law.
              Steve Jobs. Apple CEO
                Or he'll be able to redirect the output leads back into the input cap and blow it up .
                This MRA is completely new to me, have to research it. JPK's book also has no mention of it but peswiki seems to have an elaborate entry of it.
                  Thanks a lot for the feedback guys, all the info you need to get started is on the panacea university site, Norm and Joel have really done a good job in this PDF.
                  Magnetic Resonant Amplifier - Joel McClain & Norman Wootan (PDF) -
                  With low-level ultrasonic input signals, the Magnetic Resonance Amplifier (MRA) produces usable direct current power at levels above unity. This circuit is based upon the work and theories of John Ernst Worrell Keely, and is offered into the public domain in his memory
                  Panacea University
                  @ Jet, thanks man, most of the driver circuits we have been trying to find have it so the duty cycle and frequency changes when you adjust the other, so it would of been a lot of playing around, as we need to keep the duty cycle the same when adjusting the frequency.
                  Got a few ideas in the PDF, will try and get them done ASAP.
                  Ash
                    Ash, use a 555 timer circuit and put its output to a flip flop chip. This will make the output frequency of the flip flop 2x smaler, but it will be a perfect 50:50 duty cycle. And all you will need to do to adjust the frequency, will be to adjust the capacity of the 555 timer capacitor.
                    Or on the other hand, you can use some optoisolators that are triggered by the signal generator, this way your switching side will be completely isolated from the power side
                    Hope this helps
                      tobe honest, peswiki has almost nothing on the MRA. check these urls instead
                      Joel McClain & Norman Wootan: Magnetic Resonance Amplifier ~ Collected Papers
                      Norman Wootan & Joel McClain: Magnetic Resonance Amplifier (MRA) KeelyNet Messages (#2)
                      Gregory Hodowanec: Magnetic Resonance Amplifier (10 'Cosmology Notes')
                      Flickr photosets (My visits to the Nikola Tesla&Viktor Schauberger Museums, Steorn Waterways 2009 Orbo demonstration, Earthship Brighton, and also Walter Russell images)
                      My electronic music
                        ash,
                        I need information about:
                        1) How Can I identify barium ferrite magnet?
                        2) For signal generation 555 I don't believe is possible use it, because sin wave is necessary to get OU... or
                        Square wave can work well?
                        3) Have you piezos sources?, there is possible get them from the scratch, or is possible find thems electronics shops?
                          I got a importend Question too :P.
                          Where i can get Piezos!!?? Can someone sproad some pweease?
                          For a timing.
                          I figured an easy way out with the Joule Thief Circuit, to get pulsed DC.
                          You set up a Joule Thief with 2 Coils, where one has very Thick Wire and one Thin.
                          Connect the Pot to the Thick wire Coil, and the rest as usual.
                          Now you get with adjusting the Pot a Puls what starts from Zero to -???-.
                          And i think, you even get the Sinewave with it, sorry didnt scope it.
                          • #14
                            Found them, and yes Norm says they are almost identical and will be OK.
                            STEMINC - STEINER & MARTINS, INC. - PIEZO ELECTRIC CERAMIC TRANSDUCERS
                            • #15
                              There are 20-30 of them listed in this web site?
                              Could I kindly ask Norm which one exactly he has tested?
                              Best Regards,
                              Nuri Temurlenk
