Tesla Vacuum Tube
  • Tesla Vacuum Tube
    Does anyone have a good idea of the "Open ended vacuum tube" to which Tesla was referring since 1934? And I do not need copies from all the usual PD reference. I would like to know if there is any reasonable understandable drawing that shows this concept.
    If not from Tesla, then John Huthinson made such a device which is now on display in the Hiroshima City museum. Any idea on that design, concept or drawings - or how exactly this "open ended vacuum tube" is suppose to work?
    In particular, I am interested in the acceleration method and how the molecular matter was conceived.
    Any ideas regarding this part of his defensive shield (aka Death Ray) will be appreciated.
    Generator
    While on this topic; Help would also be appreciated in understanding one of the other references Tesla made in his last 15 years. He was talking of a Van Der Graaf like generator, capable of 60 MVolt "Electrostatic energy" - but generated by gas ????
    Tall order.
    Since I will be trying to make vacuum tube diode, I can make open ended (transmission plate, no reciever) one. Will let you know how it goes.
      Blowing glass
      Hi
      I came across this site a while ago that may inspire to make our own bulbs tubes etc. He covers diodes as well.
      John
      Teralab - Glass Blowing for Vacuum Devices
        Originally posted by john_g View Post
        Hi
        Not what I was hoping for, but still a very interesting and valuable link. Thanks!
          Not sure if this is still of interest, but I was able to find one image of Tesla's open-ended vacuum tube:
            I've read a couple of mentions about Tesla's tube. One said it was 50 feet long, the other said 80 to 100. It was 6" in diameter, with a small hole on the far end. It had a hemispherical electrode at the closed end. This may have had a highly polished flat plate arcoss the open part of the electrode, with around a half dozzen medium sized holes. This electrode was connected to the center of his 6' pancake coil. The longitudinal force from the electrode repelled the air in the tube, producing a vacuum at the electrode end and a pressure gradient along the length of the tube.
            I have a document from IAEA titled "Non Linear Interaction Involving Zero Energy Wave". It says the amplitude of two EM waves interacting with a neutral particle beam can go to infinity in a finite period of time. If I remember correctly, the waves are phased at 90 degrees.
              Originally posted by Aromaz View Post
              Generator
              Patent #2208217 shows a setup using Van deGraaf balls. (Don't try to download this from Google; some of the drawings are messed up.)
              Patent #2004352 shows a simple setup for generating static with a blower.
                With some googling I found the following.
                This one contains a picture:
                Tesla's Death Ray | Interesting Facts About Nikola Tesla #11
                "The device, which was based upon a large Van de Graaff generator of unique design and a special type of open ended vacuum tube, comprised a system for the acceleration of very small charged metallic particles to prodigiously high velocity, according to Tesla about 48 times the speed of sound. The particles were projected out of the tube by means of electro-static repulsion. As can be seen from Tesla's words written in a letter to J.P. Morgan, Jr. on November 29, 1934 it was intended for use in national defense."
                Nikola Tesla : Electric Discharge in Vacuum Tubes
                "Nikola Tesla - Electric Discharge in Vacuum Tubes"
                Teleforce Tesla Tesla's New Principles 1934 Force System Nikola
                "Tesla devised four inventions to accomplish these conditions, some of which he had already tested. The generating device, reportedly from some sources, is embodied upon a large Van de Graaff generator of unique design and a special type of open-ended vacuum tubeIn electronics, a vacuum tube (American English) or thermionic) valve (British English) is a device generally used to amplify a signal. Once used in most electronic devices, vacuum tubes are now used only in specialized applications. For most purposes, th, comprising a system for the acceleration of very small charged metallic particles to prodigiously high velocity (about 48 times the speed of sound, according to Tesla).
                The particles were projected out of the tube by means of electrostatic repulsionRepulsion is a film made in 1965 directed by Roman Polanski. It is Polanski's first English language film, and was filmed in Britain. Cast: Catherine Deneuve, Ian Hendry, John Fraser, Yvonne Furneaux External links 1965 films.. The tubes were to be designed to project a single row of highly charged particlesFor the fluid portion of blood, see blood plasma; also, other uses. There is debate as to whether plasma is an individual state of matter or simply a type of gas. In physics and chemistry, plasma (also called an ionised gas is an energetic gas-phase state, and there would be no dispersion whatever even at great distance (according to Tesla). Since the cross section of the wave carriers might be reduced to almost microscopic dimensions, an immense concentration of energy, practically irrespective of distance, could be attained. Specialized generation plants, Tesla estimated at that time ( 1940Events January-February January 5 FM radio is demonstrated to the FCC for the first time. January 6 World War II: Mass execution of Poles, committed by Germans in the Poznan, Warthegau. January 12 World War II: Russia bombs cities in Finland. February 2 F), would cost no more than $2,000,000 (and could have been constructed in a few months). "
                Particle beam weapon | Tesla.infoNicolas Tesla’s ‘Death Ray’ | The Unknown
                  Tesla open-ended vacuum device
                  Thanks for the picture, Jacob S. The vacuum device works just like a perfume atomizer. Check out patent disclosures for atomizers. It's interesting that physics books describe an atomizer as a Venturi tube device. Wrong. Tesla's vacuum device uses high-velocity gas to blow the air particles away from the opening of a tube connected to the vessel to be evacuated.
                  Aromaz, I knew a guy who worked for a company called Electro-Optical Systems in the '60s. They had an ion beam propulsion device that accelerated the ions by an electric field. Trouble is that they have to be neutralized as they exit or they just get attracted back to the propulsion device. The device was designed to work in the vacuum of space.
                    Here it shows a machine it calls the Tesla Van De-Graff generator..
                    Tesla's Van de Graaff Generator
