Energetic Medicine
  • Energetic Medicine
    I remember reading that a scientist shon a red laser through a salamander embryo into a frog embryo and that the from embryo changed and hatched a salamander.
    At the moment i am doing parasite cleanse which i do regularly. You have to take 10 drops of a formula 3 times a day. I got to thinking if it would be possible to put a drop of the parasite formula on a quartz slide and shine the red laser through it onto glass slide which had a drop of my blood on it it or some other piece taken from me say hair, piece of skin, spit to see if it would cause the same or similar effect as taking the formula itself.
    What does anyone reckon. I was initially thinking of spreading the laser out once shon through the parasite formula and quartz slide and shining it directly upon me while wearing protective eye wear. Seems an awesome way of knocking everything out at once. I think the formula actually contains alcholol however i could make a tea using the raw organic herbs and distilled water which would solve the problem.
    Good Test
    I guess a good test would be to shine the laser through a quartz slide onto a tray of bacteria or something and see if it dies. If it dosnt then you can try putting a drop of silver colloid onto the quartz slide and shine it through and see if it dies now. Though that said i am not shore it would work with something as simple as silver colloid, so maybe some herbal anti bacteria tea instead.
    What yah reckon. If it worked it should be possible to store the information of a substance holographically and do away all together with the substance.
      What is the laser supposed to do, be a medium of transfer of information?
      For that matter then any light will do, no?
        Any light
        According to Tom Bearden the light source has to be from infrared to UV and the experiment must be carried out in a darkened enclosure to block out interfering light. As well the pane which divides the base substance and the testing substance needs to be quartz. As well the base substance dish must be spun at 20cps to null out gravity.
        That said the experiment which converted a frog embryo to a salamander was done with a red laser. I dont know if spinning was included or whether or not the experiment was carried out in a darkened enclosure.
        My logic for using a laser was the same reason that they use it to create a hologram, that there is a requirement for a coherent light source. I dont know if quartz is necessary but was going to purchase a couple of quartz slides for 27 dollars each and a box of glass. I dont know if i am up for it though as i dont have the space or the money really and are trying to prepare myself for a physics degree math wise if i decide to enroll for semester 2.
          Imo after you do this you should alkalize so the bad buggies do not come back. Getting rid of them is one thing. Having an environment that is not inviting to them is another
          (I would suggest to try to do something with the laser for your pH, but I think that's too risky since pH in the body can be a little complex and you don't want to do anything wrong to it for sure.)
          Jessica
          Keep your mind on the aether www.PathsToSucceed.com
            Alkalizing
            Hi Jesica. My diet is pretty good. I have a raw vegan lifestyle and try as best to stick with alkalizing foods. Some people like to use chemicals to alkalize however i just dont think that that is the way to go. A change in lifestyle to a more natural way of life seems the better solution. Change the terrain and they are less likely to come back
            Jessica
              @dmonarch, can I assume that LED light mutated the DNA? If that really works, based from Keely, it isn't important wether this done in a dark place or not, since it should only be the LED frequency that is important. Maybe LED light being filtered by the source cell and transfer source cell information to target cell. If target cell interested, it would change to the source cell DNA. Just a speculation.
              But since LED is small, the target being changed should be small. And usually thing that do not have the same property repel each other. If the target part that being changed is disintegrating, it would be the sign of working replication.
                Led
                I dont know if an LED would work. I still think that a coherent light source such as a laser is necessary rather than a LED. It was not the light that actually mutated the embryo DNA but the information which was stored in the light. This is why I think a laser would be best as essentially a laser light is like a blank canvas containing no information. When it passes through the salamander ebryo the light will be altered by the information in the DNA. Tha altered light containing the information now shon onto the frog embroy passing the salamander DNA information to it. Its kind of like direct manipulation of the aura in a way.
                  I'm not sure what you mean by using chemicals to alkalize. I use sodium bicarbonate and a powder by Swanson Vitamins which is made up of different vitamins and minerals.
                  Diet is a great way to alkalize. However it may not be enough given that pretty much all the toxins we encounter acidify rather than alkalize. While lye would make one way too alkaline, most people don't encounter it day to day.
                  Toxins which acidify include vehicle emissions (funny how they study what acid rain does to buildings and landmarks but not to us) and microwave and cell phone radiation. Plus processed food acidifies and it's really hard to escape some of that getting into you.
                  Add to that that my tap water, for example is 6.5 and it's easy to see why even the mainstream medical community concludes that most adults with a Western diet (which is now prevalent in not just the west) are too acidic.
                  IMO each of us needs to actually be aggressive in combating the over acidifying properties of our current environments.
                  One other thing I just started using to alkalize is alka-trace. It's like $6.50 and I have verified with pH strips that it ups the alkalinity in water. It is comprised of "An Aqueous Solution Containing over 84 Trace & Essential Minerals in Ionic Form."
                  I am not using the recommended 10 drops per glass, but 5 instead. I don't want my water to be too alkaline bc I think it might be too much of a shock. I'm just going to gradually trying to get mine up. I'm aiming for my water to be 7.5-8. Yes that's above neutral but I know I am too acidic now so I am trying to make up for that.
                  I could not agree more with your statement about changing the terrain
                  Jessica
                    Bearden says it has to be between IR and UV, so it's visible light then, because IR and UV are on the opposite sides of the Visible Spectrum?
                    Ok, I think I know what this might refer to as I get a recollection of the light and quartz. We are talking about mitogenic rays/waves and/or biophotons. The research and works of Alexander Gurvich:
                    Normal glass will stop UV rays but Quartz one will let them pass.
                    There's a whole section about Mitogenic Rays in this book: Otto Rahn: Invisible Radiations
                      If lye is safe to drink might as well buy an electrolizer like Kangen / Envirolyte / Jupiter. I mention more at:
                      The ion reseller said the alkali water created from electrolizer is better than any solid alkali. the acidic output can be used for anti septic, maybe as mouthwash too.
                        Omg no, sorry if I gave that impression.
                        Lye is an alkaline TOXIN.
                        Things are too toxic if too far out of our pH range. But I was trying to point out that unless you encountered lye or something, you are very likely to be too acidic.
                        Jessica
                          Jessica
                          I see, thanks.
                          • #14
                            Thank for link
                            Wow thanks amigo for the link very nice book. I love reading science matarial like this the romance and honesty is all there.
                            • #15
                              Dark or Ambient light
                              I have been reading the book you mentioined are very much enjoying finding lots of cross correlations which is so enjoyable. In the experiments for treating something radiation from a source. I have to wonder if the same effect would occur if in the ansense of any light. Is the source altering the radiant light around it and transfering information to the subject or is the source producing its own uv like radiant energy.
                              Love the correlation bettween muscle tensed producing radiant energy and Reich saying the same thing about orgone
                              As well the correlation between asana and how radiant energy works is there given that most asanas are tight knit
