CloudSeeder's Gravity Wheel on Fire
Your ideas are a great heating system for the winter. I have thought of taping my heat pump into my pool for winter heat, using black plastic as a heat source. It would not have to ever kick into emergency heat, and would run more efficient with less energy. What I am trying to do is generate enough electicity to just run my 1-1/2 HP pool pump for now. If I can get it to self run, look out. Theoretically, it should support itself, especially using my torque converter setup. It would save me about $20 dollars a month for 5-6 months. Then I could think about the plastic and heating this winter. Good Luck. StealthLast edited by Stealth; 06-04-2009, 11:50 PM.
http://www.youtube.com/watch?v=JGCXGAgGdTY&NR=1
YouTube - Free Energy_chunk_17.avi has a great little engine that passes incoming fuel up the center of the exhaust pipe. The fuel is mostly water, maybe 80%. Thanks Joit!
Stealth, you're the man! Probably the only person planning to throw his heatpump into the swimming pool to save energy...
My friend hasn't brought my pipes yet, so, I am going to start on a project i've been designing for some time now. I am going to build a enclosure out of glass or Lexan, pyramid shaped, lined with copper tubing spiraled from bottom to near top. With small air vents cut into the bottom of the pyramid to allow air flow. The pipes will be painted black, as will the bottom of the pyramid. As it heats up, the rising air will be superheated and allowed to escape through a small hole in the top. But a copper wire and zinc plate(thermocouple) will be passed before exiting. I want to determine how much solar electricity I can produce with a small sized pyramid. Solar power in a small package. Good Luck. StealthLast edited by Stealth; 06-05-2009, 12:36 AM.
Plasma? A Reverse-Tankless steam engine out of a combustion engine!
It sounds good. Just maybe don't go calling it a "plasma engine" like the guys in that last link I put up. It seems not to have helped their cause much. What they really did was the inverse of a tankless water heater in my opinion. Tankless has the heat source down the center while theirs had the heated exhaust air down the outside with the fuel coming through the center pipe.
All they did was make a steam engine out of a combustion engine. Innovative but hardly "plasma". That's why the inside of the engine stayed clean <> it was being steam-cleaned. Calling a steam engine a plasma process didn't help them much or we'd have them now. Regular guys trying to use scientist's terminology just doesn't wash.
About my pool. It was only 5 x 6 feet and 1 1/2 foot deep water. If someone with a real swimming pool did my process it would be producing a great deal more than heat during the winter. But whether mine with pvc pipe or yours with real pipe surrounded by air instead of water -both being a fluid- the end result will be the same.
A tremendous blast of heated air. All you need is a small locomotive-style opposed cylinder steam engine and a generator. Absolutely no pollution. Perhaps you can do that little trick with the spiral. I look forward to hearing how well it works for you.
You might want to put a temperature-activated door on the hole, for when a cloud goes over. It will slow heat loss til the clouds move. Some black cones on the floor would help. I used plastic cones as forms to make concrete cones and painted them black. Those plus your copper pipe weight will help maintain the heat it achieves, so the clouds go over and the system doesn't drop to room temperature then have to climb the hill all over again... helping keep the generator spinning at a more regular speed.
Cones will serve as heat sinks. Two or three of your pyramid systems out in the yard you'll be making money selling current back to APCO. Be like farming sunlight. Until somebody turns you in for raising the earth's temperature => unless you make it a closed system so the hot air comes back around as intake. Circular, that's the ticket. Cycling the hot air back around might keep it running til sundown. What color will you use? Black isn't the best. Choose a good psychedelic purple. I think it soaks up more infrared, or was that ultraviolet? Whew, I've forgotten that too.
Global Climate Change is solved. Time to punch the clock.
Sorry, i been only incredible lazy, to write something more about it.
The Vid17 is about Paul Pantones Geet, a very interesting think, there are Vids at youtube, where someone did Build it, and put Orangejuice and Cola in it, but the Motor has such good compustion, that it dont cares, so far its a bit liquid.
There should be even couple good Plans out somewhere how to build it,
they did never accept his Technique, but suppress it.
Panacea has a PDF for it, and there is a Geet Page at the Web.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
Hard-to-start cold-natured-as-heck 1973 Monte Carlo that worked as a Steam Engine:
Thanks Joit, very much thanks. I'd be more than happy to convert my 1978 Ford Maverick to running his system if I had the money. Right now I don't drive much at all so it isn't on my front burner, and I got these gravity wheels in my rifle sights for 9/9/09 or before. I am more than a little concerned about what gasoline w/ethanol is doing to my Maverick fuel lines. I'll start looking into their system in earnest after the wheels are out of the way.
Cold Natured Hard-to-Start Car Engines? Add Steam!
Better Mileage <> Cleaner Engine
I had a system set up on a hard-to-start cold-natured-as-heck 1973 Monte Carlo that worked very well. It was cheap. All you needed was a big water bottle, an aquarium rock and some 1/8 inch tubing. Drill two holes in the bottle cap for the tubing. Run one tube to the bottom of the bottle and the aquarium rock. Insert longer piece of tubing just 1 inch into the cap's other hole and run it over to a vacuum port not being used for anything on the base of the carburetor.
When your turn the engine over the aquarium rock fizzes a fine mist that's immediately drawn into carburetor with the gasoline, darn engine started immediately. The mist was being instant heated into Steam by the exploding gas. This system steam-cleaned the engine also but it greatly increased engine power. I didn't have to push the accelerator pedal down nearly as much, and was then able to start the car up on cold mornings and pull away from the driveway immediately, no warmup required.
In short, I have no doubts their system worked because I understand a lot of what they were doing from my own experience.
What they did was they made the first truly hybrid engine,
a combustion fuel steam powerhouse dynamo
that is self-cleaning.
In the wintertime I added a little alcohol to keep the water from freezing overnight but the alcohol slowly dissolved the aquarium rock, that + road bumps. The Maverick makes a great Test Vehicle because it only gets 14 mpg... so any gains would be an improvement.Last edited by CloudSeeder; 06-05-2009, 11:48 AM. Reason: They made the first truly hybrid (two fuels) engine => steam + combustion <> a self-cleaning engine too!
I recently shortly researched the web for this device as well. Very disappointing research done as far as I was able to find. Incomplete replications, inventor recently passing away I think.Originally posted by Joit View PostSorry, i been only incredible lazy, to write something more about it.
The guy seemed quite sincere and convinced in the video, and while taking sort shortcuts in my mind, operation did seem to have some merit.
I would like to have measurements of exhaust gasses, see if this really is lightening the elements.
If half of it is real, it's the solution to countless global problems. A chance to start cleaning up earth, and getting some energy from our waste, clean energy.
The fuel being the water though, might be what bothers people with big stakes. The simplistic way I see the invention, it's offering a preferable environment for multiple products to react to each other, while releasing useful mechanical energy, where exhausts end up being "clean". Not only the water is "burned" right. It may even be more of a catalyst than a fuel, even if H and O work fine for burning, once available as such.
Unless someone has a better idea, the Pantone device looks worthy of more professional attention.
1100% More Engine Power Than Gasoline and Diesel Engines <> enginewow.htm
Joit: This just points out even more how critical it is to name a new energy source engine system correctly. Calling an engine the GEET when it sounds so phonetically close to GEEK was a really poor choice. It's a doggone shame when a person has such great ideas and then shoots his own horse at the starting gate, kills his own ride! Just by being poorly named.
True Two~Fuels True Hybrid Engine => enginewow.htm
My steam+air engine suffered the same fate when I called it "enginewow" as the file name. It combines liquid air with pre-injected steam that keeps the inside cylinder warm, preventing the flashed cold air (minus 320 degrees) from flash-freezing the piston to an instant stop glued and frozen to the cylinder walls. Totally without combustion of any kind, making an engine that will have 1100% the power of combustion engines and diesels.
Mechanical Heart Design as of February 2008:
Closed System <> No Combustion
In early 2008 I had an inspiration to build the 2003 enginewow.htm engine as a Mechanical Heart, truly one of "God's Engines" using Creation heart design for its own. It is in fact a Living Engine of sorts. I included a number of engineering tricks to make it have a minimum of 1100% more power than diesel engines or gasoline, totally minus any combustion. It is in fact a totally "closed system" once it is built. No more standing at a fuel pump of any kind.
It's an advanced steam engine... and yet the Steam is no longer the Prime Mover <> the liquid air is. Steam is changed to being a catalyst that makes the liquid air explode rather than just expand. It is a lot more powerful than the GEET ENGINE.
Enginewow is a double power "dual catalyst" because the steam is a catalyst (power magnifier) to the liquid air while at the same time the liquid air is catalyzing the steam to implode, multiplying the power of the liquid air. I will explain that. When the liquid air touches the heated h2o in the steam the steam instantly collapses at 186,000 miles per second creating an instant vacuum out ahead of the liquid air <> so a vacuum offers no resistance whatever to the exploding 4,361 psi air.
Actually Joit, 1100% is conservative.
Cloxxki: Better idea worthy of Professional Attention...
Truer words have never been spoken Cloxxki. Having enginewow, knowing what it will do world's above the Pantone engine or any new diesel engines, has been like falling down a well and hollering for someone to come save you, and no one hearing ya. I've been patiently waiting though because I knew one day people would want an engine that never pulls upto a gasoline pump.
Direct Air+Steam or Total Electric Generator No Plug-In Overnite
Enginewow.htm can generate the raw Power directly to the wheels or it can spin a heavy-output generator on the engine shaft... making a totally electric car. No need to plug it in overnite like giving a baby its bottle. No need to pull up to solar plug-in stations every 200 miles. No need for nuthin'. Just get in your car and drive just as much as you want.
Plenty of power for a larger tractor-trailer rig engine,
pull any load they pull now, no diesel required.
Hey Guys
After nearly 3.5 years of wrongful incarceration, primarily at Utah State Hospital, Mr. Pantone the inventor of GEET is now out and ready to move on, while also facilitating the international human rights organizations clean up a corrupt institution. A review of the GEET plasma reactor fuel efficiency technology and an article on him can be found here Paul Pantone of GEET released
Mark
