High Voltage from Thin Air?
  • Next generation SEC Engineers
    He is going to ask his science teacher some thing thanks to the Doc, thats a 6 watt fluro where is the energy coming from ? Think his science teacher better read the SEC theory paper
    • Some updates: So I stopped after 6 days the one battery loop system using SEC 18. My conclusions? that is the best in performance so far that I have ever done. PERIOD. Final voltage still above the initial 10.31 that I had.
      I ordered more SEC 18's from Dr.Stiffler and I will try my 2 battery system using 2 SECs. New design.
      I will come back later for the one battery system but for now I need the space and the SEC for other stuff.
      The battery will get to a point where the performance will deteriorate and simply stop and crash and crash fast. I have some theories about it, one being that this kind of energy is not easy for the battery to absorb and convert into useful energy. It needs time. Specially when the battery is in discharge/load mode. Either one does periods of rest to the battery where it can receive the charge or it will simply receive the charge as a ghost voltage.
      I will try with a fully charged battery and I believe it will run for months. With a discharged (dead more correct, below 10.5v 7 amp/h SLA) battery that I had on the videos things are different. Still an accomplishment if you thing about a dead battery performing at all.
      Oh, I almost forgot to say this: Voltage on the battery would fluctuate like craizy in this system. I took a log as best as I could and sometimes voltages would clime up up 1 volt and then go down and than up and so on. It kind of had a rythm. (and it is not because of the battery of the meters, I change them everyday and also use a wallmart meter).
      If you leave the meters connect you will loose some of the energy too.
      Fausto.
      • Originally posted by ashtweth View Post
        That's awesome.
        Fausto.
        • Originally posted by ABCStore View Post
          How about 12.86v 0.421mA (5.4 milliwatt)? 8 LEDs, 4 pairs of 2 parallel, semi-bright.
          ABC
          Great work. Is this using SEC 18 or 15?
          Fausto.
          • @plengo
            I use SEC18 at the moment. I could also get the whole setup to run at about 60-100 microamps, but LEDs (3-4 in series) are just glowing.
            My bigger 120,000mcd LEDs seem to be a very good match for the circuit, 3 of them illuminate our living room at only 5-7mA...
            Oh, and I don't use ground at all
            ABC
            • I have been interested lately at disruptive capacitative discharges with the aim of cohering extra energy.
              I am aware that dr. Stifler has conducted some beautiful experiments, as well as KZep, that show particularly promising results by utilizing a HV component, a spark gap and a FL tube in a special arrangement.
              Can somebody provide me specs for a replication of this experiment?
              YouTube - MRH2O2's Channel
              Baroutologos
              • Circuit info
                ABC
                @ABC
                What circuit are you using to get these results? It sounds like something that a bunch of us would like to try.
                Lidmotor
                • @Lidmotor:
                  I'm using SelfRunner-V3.jpg circuit. Both D3 and D8 are 1N4148 and my LEDs are arranged parallel in pairs, 4 pairs in series. L3 plays a big role, too. I have no clue what inductance mine have, and I've wound 8 different ones to play with.
                  ABC
                    Hey Ash, I sent you a PM but I am not sure if you will see it. It is cool stuff!
                    Fausto.
                    • SEC production of ozone
                      Hi everyone,
                      I just discovered that I can make ozone with my SEC cube.
                      I have a crystal clear quartz glass "CFL" with a small mercury droplet inside.
                      Just like I have lit my ordinary CFLs at the sphere, I could lit this 22mm diameter 24cm long "CFL". It has a strange light-blueish light.
                      A few seconds after I lit the tube, I could smell the ozone, I don't think the production is high, but it smells ozone.
                      Even though I only had it lit a few seconds, my eyes feel the effect of the UV light, normally used to sterilize water for greenhouses, to avoid plant deceases.
                      Running a high power UV tube (2KW) makes much ozone.
                      Have some of you seen this effect ?
                      Eric
                      • More diodes
                        Happy new year everyone,
                        I remember, back when experimenting with SSG, John Bedini saying on a forum that more you added diodes, more output you could get ...
                        At that time I tried with multiple diodes in parrallel but never found more output.
                        Now, after the new 6 diodes AV plug from Dr Stiffler, I think that Bedini was talking about putting the diodes in series !?
                        And what about adding even more diodes than 6 in the plug ? Did anybody tried and can give feedback ?
                        I am very interested by battery charging, because we have already the Renaissance Charger (from Bedini) that rejuvenate old batteries and gives more capacity to new batteries, so when we will have a self charging system, then electric cars and boats will be almost free to run !!
                        The batteries will never wear out, and we won't need grid power to charge them
                        But of course we need to find a way to increase charging power from Coherence, to at least, an equivalent of 10 A par battery, to recharge them overnight ...
                        @Ash
                        Congratulations for the young engineer involvement ... I think I know where the power comes from :
                        Son of a hero, the boy became a superhero , and the power is coming out of his hand !
                        By the way, what said the science teacher ? After all he is supposed to know the truth !
                        David
                        PS: give my salutations to David Pantone when he will visit you
                        • Originally posted by stephenafreter View Post
                          @Ash
                          David
                          6 appears to be optimal. Way back, i tried 2, 4, 6, 8 and ten. The output increased 75?% from two to four, maybe 15% from four to six. 8 and ten, only fractions of a percent.
                          Adding foil wings to the diode connections will also increase output.
                          Enjoy
                          • I must share this news:
                            The Bloom Box - 60 Minutes - CBS News
                            Fausto.
                            • It is a happy new year to all thanks to gestures from individual like stephenafreter
                              speaking of which David Pantone has been filmed playing wit the SEC (we made a mini doco promoting and the open source community and thanking the grass roots movements) and is taking back his wow factor of the SEC to his old man Paul Pantone, he has been working hard here
                              David showing us a vaporizer concept he found out by buying some perfume once
                              Yfrog - rimg0154
                              David working with the RV
                              Yfrog - davidwiththerv
                              Guys will have David thanking you all for getting him here and helping start the school and talking about the SEC in a new mini doco soon. More in the newsletters my friends.
                              Ash
                              • New Document - My be of interest
                                I placed a document on Scribd that some may have interest or of value.
                                An Efficient Method for Driving LED Arrays from Spatial Energy Coherence Exciters
