We have an honors project to make a spark gap. We bought an ignition coil to accomplish this. We currently do not have enough knowns to solve for all the variables involved (we think).
We are using a 555 to send a changing current to the ignition coil. We have the ability to measure its frequency. 12 Volts (square wave) are being sent through the transistor to the 2 screws of the Ignition Coil.
Using an Extech LCR, we got about 6mH off the screws, and for one end on a screw and the other on the spark plug wire we got 5.644H@120Hz 59.7H@1KHz.
We know the input EMF is 12V (2 lantern batterys) and the output EMF is 30,000V. The resistance from one screw to the spark plug wire was 12.9Kohm@120Hz and 53.75Kohm@1Khz. The resistance between the screws is 1.59ohm.
We are having troulbe because we can't find the number of turns, or the length of the wire in the Ignition coil. We are trying to solve for these, but we don't know dI/dt since the current isn't a square wave like we send. We don't have equiptment to measure dPHI(Magnetic Flux)/dt directly.
We do have an equation I=(EMF/R)(1-e^(-t/(L/R))) but we never covered that section of the book. Maybe the t is the time of the top of the square wave is when voltage is on but again, we weren't taught this section.
The longest spark we have gotten was about .4", generally it's around .25".
Any advice? Maybe there is an equation we are missing, maybe someone knows the internal workings of of Duralast C819 Ignition Coil (number of turns, etc), how to get mutual inductance from the values I mentioned above, or any other solveable variable we aren't aware of.
We appreciate any help. We are studying for finals and scurrying to finish this and a couple other honors projects.
On a side note, this is my first post here. I have everything I need to build my first Bedini this summer (after finals).
