Stealth: Thanks for your input. I checked out your thread and the video, very interesting. The self running pump is exactly the sort of thing I am thinking, only using solid objects. It appears it could be improved upon, especially if the lower end of the turbine is passing through the water.
What if the turbine ran horizontally just above the water surface and the water was pumped from just below the surface, greatly lowering the height the water has to be pumped, wouldn't that lower the input wattage required to pump the water?
Ted: Wouldn't changing the nozzle diameter to gain more pressure also require more input to the pump?
What if you attached compound pendulums to the rim of the turbine, as you suggested in the sling effect thread? It would require some complex mechanics to get everything sychronized, but it would lower the required input once spinning.
What effect, if any, would increasing the diameter and number of paddles on the turbine have?
