Originally posted by rave154
The winding pattern in the video is not the same winding pattern shown in the above link. The winding pattern in the video is actually a Rodin 360-138/2. This coil is not wrapped 120 times without coming back to the beginning. The 360-138 winding starts at pin 1 then goes 138 degrees to pin 7. Keep wrapping every 138 degrees until you get 30 wraps and end up back at the starting point. But instead of actually going back to the starting point you shift counter-clockwise 3 pins and then do another 30 wraps. Then shift one pin clockwise and another 30 wraps, shift one pin and another 30 wraps then you have a completed circuit A. Circuit B goes to the right of circuit A wire and repeat 30 wraps times 4.
It really helps if you use different colored wire to wrap the two different circuits of these 360 coils so you can see better what you are doing.
I've wrapped 3 of them so far. The last 360 coil I did took me 2 steady hours just to wrap the second circuit keeping everything tight and smooth. Have fun!
Jamie
