Originally posted by jeff_behary
I presume you understand that I am not lighty, actually I dont know him at all, but I am also from Croatia like he is.
Yes its all logical about freq what you wrote, but lets compare for example 50 meter wire length pancke coil and 200 m wire length coil .
First we put both coil at freq much lower than 1/4 wavelength , for example 50 khz, I presume they will both produce strong loud sparks.
Now we set freq that equals 1/4 wavelength= wire length for long wire coil (presume 250 khz without calcuation) , and that we put on the same freq low turn 50m coil.
Will than long wire coil give phantoms and flamish sparks more likely than low turn coil ?
So is it true that low turn wire coil gives flamish sparks at higher freq than long wire coil , or it does not matter ?
And just to say I compared low C big primary L with high C and low primary L at 500khz (for my 100 m coil) and got the same phantomish result , but higher C would mean more power(but havent used change of ballast to HV transformer to match capacitor unfortunately, higher C requires higher powered HV transformer, adjustable ballast..)
I read much Tesla stuff but at one paper which I can not currently find he says that if you use 1/4 wavelength for wire length you do not waste energy for hot loud streamers at all ...(if you tend to build any kind of wireless , ou and similar device).
Problem is that I currently dont have much different pancake coils like you to compare this claim.
And another question related to making pancakes:
we have single layered and multilayered...
Will there be any difference in behavior if coil will be build this way: Outer (opposite to center) turns witch much turns per layer and inner near center with just one turn per layer,
what about opposite, inner with much turns per layer and outer with just one turn.
. I am sure though someone can make very accurate higher frequency coils if their condensers can be adjusted in really small increments. Tesla did this with the adjustable caps under oil - good idea!
