hand-made cap
Are you asking about the hand-made capacitor wrapped around the cylinder that is placed IN the coil?
If yes, get your hands on those books I recommended. Search the web for them. I see them on scribd and some other sites.
This capacitor is very tricky. There is a aluminum former. There is craft paper put on that to isolate it. There is then another layer of aluminum plating... THICK ... more craft paper ... a longer 96 inch long by 3 inch (or so) foil, more craft paper, and then two shorter foils with a gap between them. These last two foils have TABS on them for connection purposes.
This is a hand-made capacitor. There are math formulates for plate
capacitors. The Hendershot books say this cap should be 7.8nanoFarads. There is speculation that this can be a value as large as 1.3milliFarads. It is certainly not much larger than this given the geometry.
I tried to make this using wax paper and not craft paper and got about
22nF. My attempt was very crude and lousy, using house-hold tin foil.
That foils is probably has too much resistance. Hendershot would
crack open one of his Pyramid capacitors and extract the foil, wipe off
the oil, cut it to the dimensions he wanted, and then wrap them around
his cylinder former. If he failed to get the right value, he we take
it apart and do it again. This is a KEY element of his device.
Here is a video of a guy making one...
Hendershot Generator Nachbau Teil2 - Öffentliches Projekt - YouTube
