components...
The AC caps are labled here on the schematic you posted.
80MFD ... and 40MFD.
I think what has not been fully worked out is WHY you need
these values of capacitance. These would be appropriate
for "motor" and or "relay" speeds ... i.e. low frequency.
But I ask myself ... why can't I use 30MFD instead?
I was able to find 30MFD caps, but not 40MFD or 80MFD.
I searched and searched several times in a surplus store.
These are expensive.
Re: voltage rating of these caps. The bigger the better probably.
So 200VAC to 450VAC say.
These are pretty dangerous caps, btw. If one was sitting on your
bench FULLY charged ... it has lots and lots of joules of power
in it. If you were to forget and reach over and touch the contacts
by mistake, you could really get hurt. So always short them out
when handling them ... and keep them shorted when stored.
Give them as much respect as you would an open knife.
On the Hendershot coil, 3 of them are wound in the basket weave style,
and coil D in your diagram is wound AROUND the lower 64-turn one.
I think you wrap that lower one with some tape first, and then wrap
coil D on it.
coil D on it.
