kyle_dellaquila In the experiment with the RF-amps the AM got completely lost, so no sword-like streamers, no QCW effect. And no point changing the input wave form.
As for the coherer, My idea is something like this:
First one has to remember that the wave does not necessarily have an electric component. It is a density wave in a neutral gaseous medium which is responsible for electric effects.
Let's consider a charged capacitor. When such a density wave passes, for a short moment the pressure of the medium between the plates increases. (as a result of the increased density)
From the perspective of the capacitor plates this is the same as increasing the distance between the plates, as more matter now is between the plates.
This results in a short moment of decreased capacitance, which with the same charge being present will result in a higher voltage.
Withe the grains in the coherer it is much the same, but as the coherer is already pushed to its (voltage) limit, the increase of voltage will bridge the gap between a few grains, thus putting more stress on the remaining un-bridged grains and thus causing an avalanche. Once a current flows, so called micro welding occurs.
Now that I write this down, I think a capacitor could be used as well... in a similar set-up as in an electret microphone. No need to de-cohere...
Worth an experiment...
Ernst.
Ernst.
which works fine at low frequencies (<100KHz) but at the frequencies I need, it isn't fast enough.
Here is what happens (if all goes as planned):
