Part 8, Crew Cabin and Landing Gear
The Crew Cabin is stationary relative to the other clockwise and counterclockwise rotating components. This Crew Cabin may house: humans/animals, electrical circuitry, control systems, etc. The Crew Cabin is set on the top of the Outer Hull with one of the Main Shaft Halves sticking through the center.
You may see there are also portholes in the Crew Cabin for people to presumably look out, it's not necessary to include them in smaller OTC-X1 models unless there's an actual functional purpose to it.
"Otis T. Carr: This too... this is a... the beginning... of an answer to the solution. We have... capacitor plates and electromagnets... a... as a part of this system. Now... this is counter-rotating. The electromagnets rotate... in one direction... and the... accumulator... the battery... rotates in another. The capacitor plates rotate in conjunction... with the... battery... so that we have a clockwise and counter clockwise rotation. Now... the third system... is the cabin that maintains the crew. This does not rotate. It is fixed... due to the fact that the two bodies are rotating clockwise and counter clockwise as an extenuation of the cabin. Therefore... the system that causes the craft to become... escape from the gravity pull. The craft itself... itself (do) this system... still has internally gravity... because it still has the same weight... that it had in the beginning... there is no lose in weight." (Long John Nebel 4-19-1958 Radio Interview, 1958).
Keep in mind that the Crew Cabin should be mounted in such a way that it can sit comfortable next to the Outer Hull, and not spontaneously rotate counterclockwise. Remember that the Crew Cabin is in an alcove that is stationary and not connected directly to the Outer Hull, even though its quite close to touching other components. Also, it seems indicative that the material of the Crew Cabin is aluminum or some insulating material due to the colors/shades on the pictures. Now, there are parts of the Otis Carr story that involve more components being present in the Crew Cabin, I will cover those at a later time.
Now, the Landing Gear is also stationary, the same as the Crew Cabin. The Landing Gear is commonly seen as having 3 hemispheres which are mounted on Y-shaped structural shape, each hemisphere place on each end of the "Y". The below pictures may hopefully give a better illustration of what I'm saying.
You may see in the first picture, from the OTC-X1 Toy Kit Plans, that part of the Main Shaft Halves sticks into the Landing Gear. This shouldn't interfere with the stationary aspect of the Landing Gear however, and should be engineered with that in mind. Also, in the above picture the hemispheres are replaced with wheels, consider that the above 6-foot model is about 600 pounds, so keep in mind wheels are more practical when the weight of the materials goes up. However, the above model was using mostly machined parts, and the first "flying" 6-foot model was only 16 pounds since it used very light materials.
"Otis T. Carr: The last one was six feet... when we put a leading edge around... a... six inches... a... of diameter... great than it was before. The... these... the last model that we flew... six feet in diameter... hand made believe me... all but the machine made parts... of the electromagnet and the accumulator.
Ellery Lanier: What was the weight... of this...?
Otis T. Carr: The mechanical parts in the model... weighed... a little over... 16 pounds. The... the actual... a frame of the model... weighed two pounds and 7 ounces..." (Long John Nebel 11-15-1958 Radio Interview, 1958).
"Otis T. Carr: ... it was built light. Believe me... it was built the same as a model airplane. Now... and the heaviest part about it was the... was the... roller skate bearings... which we got for nineteen cents... union hardware." (Long John Nebel 11-15-1958 Radio Interview, 1958).
Summarization:
1. The Crew Cabin is located in an alcove in the top half of the Outer Hull. The Crew Cabin is stationary and doesn't rotate clockwise or counterclockwise, but has part of the Main Shaft Halve sticking through the center of the Crew Cabin. The Crew Cabin could include: control systems, human/animal accommodations on larger OTC-X1 craft, or other useful components/systems. The material of the Crew Cabin appears to be aluminum or an insulating material, since control devices and humans are housed in the Crew Cabin care should be taken to insulate the cabin from electrical sources.
2. The Landing Gear is located in an alcove in the bottom half of the Outer Hull. The Landing Gear should be stationary relative to the other rotating components, it does not rotate. The Landing Gear may support the OTC-X1 Circular-Foil Spacecraft using 3 hemisphere's, or 3 wheels depending on the weight of the model. The Landing Gear has part of the Main Shaft Halves sticking into the structure of the Landing Gear, however it should not effect its stationary behavior. Also, The Landing Gear's structure seems to be made of an insulating material, while the hemispheres seem to be made of a metallic (aluminum?) material. However, the Landing Gear itself should be insulated from electrical sources to prevent electrical flow in unwanted places.
References:
Long John Nebel 4-19-1958 Radio Interview Transcript Part 1: https://hello-earth.com/otistcarr/in...1958part1.html
Long John Nebel 11-15-1958 Radio Interview Transcript Part 1: https://hello-earth.com/otistcarr/in...1958part1.html
OTC-X1 Toy Kit Plans: http://clandestinedisclosure.com/ass...allpagesbw.pdf
The Saucers That Time Forgot (The Life and Legend of Otis T. Carr - Part 3: The Trial): https://thesaucersthattimeforgot.blo...carr-part.html
Otis T. Carr and Dimensions of Mystery Facebook Page: https://www.facebook.com/OTCX1/
WKY KTVY KFOR Archives Video (F2013.134.1.00208): https://www.facebook.com/OTCX1/video...ll_videos_card
Summarization:
References:
