  • All that fuss about caduceus coil is strange : when we are winding normal coil it is almost like caduceus kind. The only difference is that next layer is separated by a tape or so but I wound a coil without that and each turn from new layer is going between two turns of previous layer so it crosses almost like caduceus coil.Also each layer is wound in opposite direction but current is flowing in one direction - is this maybe the reason why normal coil has fixed magnetic poles ?
    I'm not expert but just think about it, please
    • spark gap parallel or serial
      Originally posted by cognito
      Hello to all,
      Since we want higher frequency (say above 50kHz) coming from the nst we use a break and cap connected to the primary air-coil.
      We have for example 60Hz nst and primary air-coil is 253 micro henries. We want this to resonate on say 100 kilo hertz.
      In Tesla notes we see this circuit used for maximum current though the primary Lp and less current through break. Break is parallel and not in series!
      Also this circuit has minimal dampening.
      How do we adjust / calculate the break and the caps Cp,C1 for attached picture and go from 60Hz to 100kHz?
      Should the frequency from S be in phase with the Cp Lp resonance frequency?
      If the C1 caps are charged and the break kicks on the wrong time, the LpCp resonance frequency is disturbed?
      I'm not an expert, only try to understand this. If we use Don Smith systems this is the beginning for resonance system.
      Best regards,
      Cognito
      I've seen those drawings in Colorado springs note and even in the book inventions of tesla. In many drawings the spark gap is in parallel, does anybody know why. And also if you put a high voltage diode, it rectifiy half wave and does the SG in parallel shorts the cap Cp to ground ??? And by the way it is a nice thread. sorry for the english, it's no my first language...
      • WOW 941 posts and 32 pages and no free energy yet??? Hope I don't get to old and die waiting for this thread to amount to something. Any body want to bet this Don Smith thread goes four hundred pages and still want to know how to get it working. DON SMITH never had a working unit.
        • Originally posted by zilano
          step down is always 1:1/4
          so step up is 1/4:1 and step down is 1:1/4 ?
          If yes then everything is pretty clear now. And I thank you dearly for all your help
          • The Smith Tensor Coil was given to him from "topside" along with other designs, that he then experimented on and found that it did not follow conventional EM theories.
            The Tensor Beam
            Verbatim extracts from the Smith archive
            Tensor Beam
            We were told about a system which uses a radio transmitter as an energy source but has a special antenna converter, which radiates doughnut shaped waves, which are not time functions. One ferrite core, material with the highest permeability and dielectric constant, about 8 inches to a foot long, and about 1 inch in diameter. About 20 feet of plastic insulated #14 electric house wire. Starting at the center of the wire and at one end of the core, wind on the wire as closely as possible, with the first turn under and then over, so that the winding will be exactly symmetrical. It will start at one end of the core and finish at the other end and will resemble a solenoid with a bifilar winding. It is important that the winding be exactly symmetrical.
            Still unanswered questions and parts list needed:
            How did Kapanadze and SR193 use the Caduceus coil to get Free Energy from their units?
            How did Zilano use the bifilar coil to get Free Energy of 10 kw to power a house?
            Cheers Mike
              well just get nst solid state 30-40 khz. 3 kv or 4 kv
              we use lengths to vibrate em without needing caps. we r just inducing half wave just to make em vibrate at their natural frequency and since natural frequency of vibration depends upon the length of coil thats why lengths r important. we use mhz range coz if we use khz range lengths will be veryyyyy long.
              suppose u have 2 inch radius primary
              so length one turn required =2*3.14*2=12.56 inches/12=1.046 feet approx
              if u need 5 turns then length required=5*1.046=5.23 feet
              and ur secondary length will be= 4*5.23=20.92 feet
              now u can calculate ur frequency at which its gonna work
              length(1/4 wave)= 246/frequency in mhz
              5.23=246/f in Mhz
              f in mhz for quarter wave= 246/5.23=47.03 Mhz
              now if u have 3 inch radius for secondary
              length required for 1 turn=2*3.14*3=18.84 inch/12=1.57 feet
              so no of turns in sec wil be =20.92 feet/1.57 feet=13.32 turns
              so u will have 5 turns primary with 2 inch radius and 13.32 turns in secondary with 3 inch radius pvc tube.
              thats how its calculated.
              we r not using full lengths for turns we need extra for connexion also so we adjust turns accordingly say 3 turns in primary and 10 turns in secondary. keeping lengths same for primary=5.23 feet and secondary=20.92 feet
              if u feed 2000 volt in primary 3 turns then voltage per turn=2000/3=666.66 volts
              and since we have secondary 10 turns then voltage per turn across secondary is 666.66 volts
              so full voltage across secondary is 10*666.66=6666.6 volts = 6.6 kv approx
              since we treat secondary coil as magnet we have to make space for blotch wall(the middle neutral space of N____S middle join. so we make 5 turn_____5turn
              ____ is sec coil middle in straight line its length=primary coils total turn width. so primary sits between this straight wire joining 5 turns and 5 turns of secondary.
              0000000000000
              0=secondary coil turns
              0=primary turns
              hope u understand now
              regards
              zzzz
              Will be the same calculation for ferrite rod? We use 2 inch diameter for primary and 3 inch diam for secondary?
              For step-down transformer with ferrite rod:
              15Mhz resonance is 20 metres primary and secomdary is 5 metres cw and 5 metres ccw?
              Can i make secondary on the same diameter tub with primary?
                applies to aircore only
                rgds
                Can you make an example of coil calculation for ferrite rod system?
                Ferrite wil have a dielectric(isolation) in the middle of the rod?
                • Simplification
                  @zilano
                  can we simplify the setup like this one attached and still having an ou device?
                  • Thank you .
                    You made it perfectly clear.
                      yes the circuit will work if u have 50/60 hz nst and cap must not be used.
                      for higher frequencies it wont work coz mot has iron core and it will saturate. as the pic u depicted for that u have to use pure dc with a bridge and use cap to make primary of trafo to oscillate at 50/60 hz. u have to measure L for trafo(primary 2000 volts) and calculate C. and feed full dc through spark Gap.
                      power wud be more than input but not quite large. coz its single step u need multiple units like these to have abundant power if all units connected in parallel(outputs)
                      rgds
                      zzzz
                      I think it could work with higher frequencies, just Nst should be like Don Smith circuit. Doesn't NST contain the same coils as big tabletop device? If you have NST working at resonance and know the length of secondaries and primary is 1/4 wavelength. You see ?
                      Step down would be problematic.
                        for ferrite use nst voltage 1kv. use single ferrite for primary keep secondary air core. and calculate according to radius of primary and add 1 inch to the radius of secondary and calculate urself according to the aircore style.
                        rgds
                        zzzz
                        THANK YOU, Z
                        I must add capacitor in secondary for resonance with primary.
                          there r 2 kinds of nst one with iron core 50/60 hrtz and one with ferrite core 25khz to mega hertz range.
                          so we cant use higher frequencies with iron cored else it will melt.
                          rgds
                          zzzz
                          yeah, sure I thought about ferrite core one , but you're right - would be hard to find matching cap in secondary for full wave resonance and properly made NST also
                          • Piezo you say,of course!
                            Thanks zilano ,the funny thing is that I was doing some research today on piezoelectric transducers.
                            I see a bright future ahead.
                            • Here is a new Kapanadze video:
                              Images of the device starts at 17 min into the video
                              Beautiful GEORGIA TK.swf - YouTube
                              xenomorphlabs comments over at overunity.com:
                              Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
                              Caduceus Coil
                              Ground connection
                              Coil length
                              Furnace ignition HV unit:
                              Furnace burner HV unit:
                              Cheers Mike
                              • A little off topic, but an interesting way to make a strong magnet.
