  • Originally posted by Eng.raied View Post
    GOOD Work blackrobi
    excellent notes
    an special note.
    if u r following Don smith. then follow the coil pattern as shown by don smithprimary thicker few turns and secondary thinner many turns. u will harvest more. the step down thing i made u learn how to do it. so u all understand how its done.
    so step up now and step down later and see power u get with
    plauson step down
    Don smith stepup and car coil as plauson step down
    and see the magic.dont forget to earth the output 12 volt one terminal earthed
    zelina
    • Originally posted by soundiceuk View Post
      GLAD TO HAVE CAUGHT YOUR INTEREST XILO
      Latest schematic v1.3
      http://f1.grp.yahoofs.com/v1/0EjTT20...ver%20v1.3.pdf
      You can use 15v, 10,000uf to build a good proof of concept device.
      The reason the schematic changed is because of the new HVM.
      Available from:
      High Voltage, High Frequency Power Supplies
      1 @ $19.95ea.
      10-24 @ $14.95ea.
      25-99 @ $13.95ea.
      100+ @ $11.95ea.
      Here are just a few of the shots I took of the MiniMax3 Lenz kindly sent me, in raw format.
      Pretty Standard NPN BJT! These guys have been the work horse for so many experimenters.
      The SEC version is a 70V / 10A / 75W BJT
      MJE3055TG ON Semiconductor | MJE3055TGOS-ND | DigiKey
      This will match it pretty well.
      L1 & L2
      Custom Wound Mystery Crystal Radio Coil
      eBay - The UK's Online Marketplace
      Want to know anything else pm me.
      Hi Soundiceuk!
      Thank you so much for your reply with update. Thanks for the quick response. You are very helpful guy.
      The above link didnt work reporting page not found. Can you please post a working link? for Latest schematic v1.3
      Thanks in advance.
      Best Regards
      Xilo
      • The difference that Plauson makes see it yourself
        Don Smith replication first step - YouTube
        compare with
        Don Smith primary driver to toroid - YouTube
        hope u understand which is better white and cold or yellow and hot
        rgds
        zelina
        • Originally posted by zilano View Post
          an special note.
          plauson step down
          zelina
          hi zilano
          ok let's go to step up set up
          * the pvc 2" Diameter L2 (No of turns=?)
          * the pvc 3" diameter L1 (No of turns=?)
          * cables length the first one 16 m
          * length of second cable 4m
          * flyback driver(i don't know the frequency) depend on resonance of 8t+4t of driver
          * capacitor homemade
          *I have LCR meter
          waiting your suggestion.....
          FREE ENERGY = FREEDOM
          raadawad[at]yahoo.com
          eng.raied[at]yahoo.com
            hi zilano
            *I have LCR meter
            well go by rule of thumb. say if u have L 2 feet then make secondary 8(4ft+4ft) feet dont worry about frequency it will be in khz range. measure L and choose C according to the frequency u wanna oscillate primary. do for secondary. for secondary u know frequency for primary now choose cap for secondary that it will oscillate with frequency of primary. use resonance frequency calculator. am advising caps to u on primary and secondary so the frequency of resonance wont deviate and wont need fine tunning much by sliding.
            connect don primary as i have shown as suggestion to guruji with flyback pic.
            u only have to feed Dc as u have diode in built in ur flyback so u dont need to use external diode.the primary will oscillate according to its L and C combination frequency.
            rgds
            zzzz
              rgds
              zzzz
              the charged capacitor can not spark when it is up more 400 volt and neon don't do the for the plausun converter
              what size and value of cap u suggest?
              what power limitation of circuit (caps ,output trans. of plauson converter ,output cables?
              L2 cw+cw or cw+ccw ???
                wind primary cw and secondary cw cw.
                u can change primary cw to ccw by rotating 180 degree and inserting in tube to match phase with secondary.
                sorry due to net failure its late reply.
                ps: keep refreshing the forum page so u see latest replies else the reply takes time to reflect in forum already opened page
                rgds
                zzzz
                  rgds
                  zzzz
                  do u have drawings of car coil as plauson step down?
                  • A bit off topic but still my post should be interesting who study E. Leedskalnin work:
                    Help with Ed Leedskalnin Riddle , any idea .
                    Hello,
                    I am looking for replicators who can assemble E. Leedskalnin flywheel and PMH in a way he did. Please let me know if anyone is willing to do hard work
                    I think I finally did put puzzle pieces together on E. Leedskalnin generator and we had proof of his fuelless generator almost for 70 years..
                    So instructions to remake one should be as following:
                    1) The flywheel is made from same pole magnets what are squizzed together by force to make sharp magnetic poles. Because of that we do not have strong magnetic field in then edges on the magnets. The strongest point is only in place where two same poles are did put together. With resonant spinning they make maximum electricity in PMH and cause no drag. Bye bye Lenz law if I am correct...
                    2) The 3 poles are fit in depth of PMH.
                    3) The PMH is inside of metal core (the box in photo). That amplifies magnetic currents (in E. Leedskalnin book).
                    4) The spark gap is used to take power out of high voltage from PMH on peaks only when magnets are approached already. NO MORE OTHER CONNECTIONS what are killing free oscillation!
                    The copy of photo is in http://imgbin.org/images/8388.png
                    The analysis of flywheel is in Flux Flow Analysis of the Edward Leedskalnin Flywheel | Energy Research
                      do u have drawings?
                      [size=4]
                      USE 2 MFD 8000 VOLT CAPS AND CAN ADD MORE FOR MORE POWER.
                      SEE CAR COIL USAGE BELOW
                        this is what you need...
                        the plauson converter is basically a tesla hairpin circuit, paralel spark with series caps...
                        Light, I Am!
                        • could somebody - ANYBODY please tell me how to post a reply to any one of the available threads. THERE DOES NOT SEEM TO BE ANY INFO ANYWHERE HOW TO DO SUCH A THING!!!!!!!! thanks to whoever!!!!!
                          • how to attach downloads and attachments of complete photos and materials of don smith
                            I have some free energy device photos and material lists and downloads that I would like to send to all of you that would enjoy such. I simply need to know from any of you how to do this. I use IE on my dell computer in Iowa Louisiana, but I dont know all there is to know about navigateing on the energetic forum to get the job done ina suitable manner! all comments graciously accepted. thanks plenty, mike.
                            • Originally posted by clarence View Post
                              just in the page whom u want to refer and post kust click on quote a window will open and then write reply or woteevr u want to post. THEN CLICK SUBMIT REPLY.if u want to post without refering anyone as independent post scroll down to page where you see Post
                              SEE PIC BELOW
                                CLICK POST
                                THEN A WINDOW WILL OPEN JUST SCROLL DOWN
                                AND U WILL SEE A BUTTON SAYING ATTACHMENTS CLICK THAT ANOTHER WINDOW WILL OPEN AND IT WILL ASK U TO BROWSE THE LOCATION OF THE PICTURE FROM YOUR HARD DISK LOCATE THAT AND CLICK UPLOAD AFTER UPLOAD CLICK THAT WINDOW CLOSE
                                AND CLICK SUBMIT REPLY BUTTON
                                UR DONE AND U WILL SEE UR ATTACHED PIC IN THE POST.
                                SEE PIC BELOW
                                SEE PIC BELOW
