Originally posted by xilo
Well good luck with the hacking but from what I know hacking 1024 bit encryption even with a room full of super computers doing a brute force attack could take thousands of years if you are very lucky. Still good luck with that and thanks for the info.There is no important work, there are only a series of moments to demonstrate your mastery and impeccability. Quote from Almine
Opinion On Correa Invention Energy Conversion System
@RAMSETOriginally posted by RAMSET View PostOpinion on Correa Invention
Edit... HMMMm I see this link to Dr.Harold Aspden's evaluation of Correa's Tech is Not going thru
Google it!!
Correa's version.
Lots to learn about in this beautiful world !
LOTS!!
Chet
Thank you the following link works
Regads
JJ
that link didn't work either so I found it here
Harold Aspden - Science Report 8 - Power from Space - The Correa Invention, 37p
Xilo's findings and more...
Hi Xilo and others,Originally posted by xilo View PostHi David Fine!
I found text which states that using avramenko and earth we can harvest unlimited energy but its DC we have to invert it. the power from ground is real and is useable as such like a battery.the kapanadze generator uses same principle it pumps charges from ground to the capacitors. the frequency of tesla coil just increase accelerating effect on the charges that are pumped from ground.
XILO
I have been following Xilo postings.His lastest finding found resonance with what I discovered recently.
Someone working on the testatika found and confirmed what Xilo and others have been emphasizing.
Here is a link to a site that appears to have confirmed by experiment (lots of pictures and schematics.Use google translate to get the full text) what Xilo just posted...
Kapazitiver Transformator
and Testatika Experiments
I found it very informative.Hope it helps in your quest.
I have confirmed this.I have confirmed on two occasions electrons been sucked from the ground.No arguments here.Naudin has some excellent postings regarding the avramenko.I am now aiming at lighting a bulb and yes, as I have mentioned before, powering a real noisy drill at some point in time
Keep up the good work !
GedLast edited by Gedfire; 06-19-2013, 08:37 PM.
Hi folks.
Thanks for your input Xilo and Gedfire
For David
The capacitive transformer thingy explains how Tesla`s Wardenclyfe Tower principle is, also E.V Gray conversion tube & the Testatika thing.
To not forget resonance also, very important !
Nice that things are clarifying up those days.
cheers.<< BP Ultimate + Shell-V Power + Allies (opec) = the Ultimate Power Aligators to Suck People`s Blood !-! >>
Confirmed Cold to Hot Converter
You are welcome Peculian,Originally posted by Peculian View PostHi folks.
For David
cheers.
How do you achieve resonance with a capacitive transformer? My understanding is that the problems of inductive type systems are almost non existent with a cap based device.
We know we can replace the testatika wimhurst with NST's flybacks etc and provide feedback to the starting battery or cap SR193 /Kapandanze way/Don.But how does resonance come into play here?
Hi All,
Today I fired up my flyback but this time attached both positive and negative to a spark gap.Then I connected two caps using Plauson/SR193 style.Then I connected a neon bulb and bingo! It lit up! Fluttered then became brighter.
I disconnected it and used an incandescent bulb instead.No light but the bulb got hot....
Next I am going to us an earth ground and bigger caps.
Anyone knows how to mod a DMM to measure HF voltage.Like 6khz? I am thinking using a diode bridge and cap to get smooth dc.Is this a viable option?
GedLast edited by Gedfire; 06-25-2012, 03:10 AM.
new vid
hi all, just here workin, i am working on the stepdown setup for my stepup coils
3 watts AC input,and 20 watt halogen lit up bright
Don Smith Device Project Part 31: 3 Watts In, 20 Watt Halogen Lit Bright - YouTubeIn the beginner's mind, there are many possibilities.
-Shunryu Suzuki
Very neat KD.Originally posted by mr.clean View Post
Now that you have a known output, might it be better to match series/parallel bulb loads to your existing circuit without disturbing the coils ? This in order to establish an optimum mutual coupling, and thence the necessary subsequent transformation ratio for your desired loading, for electricity is of electron spins, alignments and excitation no matter what frequency (not cold or hot!).
Also, as I mentioned to Farmhand, can I suggest that you concentrate on the plasma within your 'spark gap' metals, where ionisation needs to generate an aligned plasma (not just a 'spark') in the gap, such that a resulting photonic avalanche can fractionally dissociate spark gap matter radiantly to energise electrons and thus cause excess charge flow via oscillating resonance.
Try adjusting the gap for output with an insulated mechanical coupler (plastic knitting needle) whilst the circuit is running ? Are those plated steel (Zn on Fe) bolts or just plain ? Different metal surfaces, including dope like plating, will most likely generate different lamp intensity outputs ?
( I just noticed I am now a "Senior member" - I don't like the idea of seniority labelling in SHARED environments ! )Last edited by GSM; 06-25-2012, 08:06 AM.
Hi Gedfire !Originally posted by Gedfire View PostYou are welcome Peculian,
I am not quite sure but resonance is achieved when you tune two different circuits into a frequency which they both responds and "communicate" or so to say to each-other. (?)
Like tuning your radio receiver to the desired broadcasting AM or FM radio-station frequency.
Tesla mastered the tunning to a point that I doubt others are able to reproduce, except as I can see by Eric Dollard.
He (Tesla) "pumped" radiant impulses to the Earth in relation with it`s atmosphere.
And he could collect back the same amount of energy pumped without power losses or diminishing it.
And here I will speculate to say that he managed most probably how to get more out of the excited Earth in relation with it`s atmosphere than what he feed to his wireless power "transmitter". (?)
By my wild guess I would say these circuits most probably have other tuning problems unlike inductive circuits. But I am learning so I am not aware yet to what problems might they be. (?)Originally posted by Gedfire View PostMy understanding is that the problems of inductive type systems are almost non existent with a cap based device.
Ged
[some food for thought:
Capacitive Transformer George Wiseman 1
Well, we need to study more and experiment moreOriginally posted by Gedfire View PostWe know we can replace the testatika wimhurst with NST's flybacks etc and provide feedback to the starting battery or cap SR193 /Kapandanze way/Don.But how does resonance come into play here?
Because, without resonance = no power, no juice in our bucket.
Originally posted by Gedfire View PostToday I fired up my flyback but this time attached both positive and negative to a spark gap.Then I connected two caps using Plauson/SR193 style.Then I connected a neon bulb and bingo! It lit up! Fluttered then became brighter.
Thanks for sharing the goods.
InterestingOriginally posted by Gedfire View PostI disconnected it and used an incandescent bulb instead.No light but the bulb got hot....
wow, Big Caps ? Be careful with those beats buddy.Originally posted by Gedfire View PostNext I am going to us an earth ground and bigger caps.
Earth Ground is a Must for gain in power.All succesfull inventions started with grounding to achieve what they achieved.
I personally dunno, but does your DMM have a frequency counter ?Originally posted by Gedfire View PostAnyone knows how to mod a DMM to measure HF voltage.Like 6khz? I am thinking using a diode bridge and cap to get smooth dc.Is this a viable option?
Also be careful not to screw up you DMM !
@Mr.Clean
Thanks for sharing the goods with us all
Hope you go ahead with more success !
cheers and Regards.
Hi Gedfire,Originally posted by Gedfire View PostYou are welcome Peculian,
Ged
you did not use the toroid transformer thats why the bulb didnt light. use toroid transformer after the plauson caps.
thanks and regards
dunfasto
I think the Tesla power transmission system should be used to understand what's going on. I made quick sketch on how it would look like:Originally posted by dunfasto View PostHi Gedfire,
thanks and regards
dunfasto
Mr,Cleans home heater
Mr C
Take that bulb and run it like this [see pic bulb in water]
first time hooked up to the mains [the way God meant it to be]
the second time hooked up the way you have it in experiment.
Put a kilowatt meter in series
measure temp before and after a timed run
Compare temps over time and input.
you'll know in 5 minutes if you have something special going on.
Thx for sharing
ChetIf you want to Change the world
BE that change !!
battery charger
Hi dunfastoOriginally posted by dunfasto View PostHi j dove,
thank you so much for the schematic and the pictures. very impressive. am very impressed that you are using rodin coil.
is your circuit capable of self run? did you try it for overunity?
thanks and regards
dunfasto
no i never tried to make it self run and its not ou just made it to charge bats. that had problems with , made other designs for desulfating the one i showed you is just a low power prototype but it works well and on the same principle as the devices that are described here.
cheers
Jeff
Don Smith Device Project Part 31: 3 Watts In, 20 Watt Halogen Lit Bright - YouTubeOriginally posted by RAMSET View PostMr C
Thx for sharing
Chet
So just throw it in a glass of water? It does heat up MAJOR so ok, i'll try that, hey what is the heat formula? anyone know off hand?In the beginner's mind, there are many possibilities.
-Shunryu Suzuki
