Originally posted by zilano
Yeah I was wondering about that. Any way to calculate that? Never mind, I just tested, inductance changes on the meter when I insert ferrite core. Cool, thanks nico!Originally posted by nico View PostWell, I think, L must be with ferrite core else we will need huge capacitor, something like 100 000 uF for air core.
Maybe you can tell us how it look a step down transformer?Originally posted by zilanowork accoding to the voltage u calculated in ur secondary and make trafo according to that but b4 trafo u will be having hv so use cap for 60 hz combo according to that voltage.
WELL RULE OF THUMB ITS ALWAYS BETTER TO CHOOSE A STEP DOWN SO U HAVE MANAGEABLE VOLTAGE AND ACCESSORIES.
LC Resonance Frequency Calculator at WhatCircuits.com
Primary many turns on 2inch diameter? or on 3 inch ?
Secondary will be inside primary or outside? what diameter?
Well, I would need a 5H coil to even make it slightly affordable at 1.5kv. Min voltage for for electric to jump through air is 350v. Even a 500v cap at 1uF is somewhat expensive. I think I'll just study the power factor correction nomogragh thing.
nico,
I wrote a program to help me calculate turns, diameter size, and voltage. Maybe it will help, maybe not.
DonSmith.exe - download now for free. File sharing. Software file sharing. Free file hosting. File upload. FileFactory.com
Thank you , The calculator is good , i will use it.Originally posted by drak View Postnico,
I believe you can make L to be a transformer, step down. Make on L some turns and maybe will work.
Capacitor discharge in this circuit won't do what Tesla had in 1st place - accumulated energy discharge. When you discharge capacitor, you want to use all energy inside of Tesla Coil primary so it will have best effect:Originally posted by Itsu View Post@ All,
Regards Itsu
This is proof, still not hard but proof! :thumbsup ( for those who can read russian)
- possible circuit is based on same principle like I mentioned before. Just additionally it got 2 secondary coils for full cycle usage. It is already fully explained by Romanov in (Russian, needs translation)
Hopefully that helps to understand how things work
You cannot understand how a system works by simply looking at a schematic
the geometric location of the primary as opposed to the secondary is very important.
The design itself will determine whether you achieve ou or not.
Of course , you need comply certain rules for making Tesla Coil work as electrostatic machine not just as HV transformerOriginally posted by Dave45 View PostYou cannot understand how a system works by simply looking at a schematic
My thoughts in different forum:
Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
And my simple test for lightning up lightbulb with 1 wire from ground and other to coil (the circuit is not grounded): Tesla Earth Electricity - one wire electrical power - YouTube
Have fun
Originally posted by T-1000 View PostOf course , you need comply certain rules for making Tesla Coil work as electrostatic machine not just as HV transformer
Have fun
The fly-back transformer is used to charge HV capacitor which discharges over Tesla Coil primary and spark gap.
That long wire on the ground is grounded. I did not use ground from 220V socket ground connection for sake of electronic devices around what already are going crazy from spark gap action and scalar waves...
The wire connects to 200V 15W bulb 1 side. The wire from other bulb side goes to one of secondary coils. So you get earth and coil as 2 charged electrostatic capacitor plates and it works quite well even not in perfectly tuned Tesla coil.
P.S> If I touch one of Tesla Coil secondary coils , i get spark between my hand and coil but it does not hurt - the cold electricity...
I just found quite important information related to topic(from Dynatron in 001-lab.ru):
Трансформатор Тесла и новая энергетика ч2 - YouTube
Новая энергетика: ответы на вопросы - YouTube
Новая энергетика: ответы на вопросы ч2 - YouTube
Трансформатор Тесла открывает путь к новой энергетике - YouTube
(all in Russian, needs translation)Last edited by T-1000; 09-24-2011, 02:34 AM.
Hi,
In one posting I did, you can see a picture of the setup with two transformers what Don made.
I'm curious how Don solved the 240V/50Hz or 120V/60hz generation from his devices. If someone has a better quality of the picture please post it here. It is difficult to see in the picture if he charged a capacitor or capacitors for temporally energy storage for a load (inverter). It would be nice to identify the components.
This simple inverter circuit can be used to generate 240v 50hz 500Watts from 12v DC from a reverse connected 240V to 12V transformer.
500W or higher is possible if you change the MOSFET for higher ratings.
555 timer is not used, but a PIC controller to generate the timing signals for 50hz or 60hz.
Since caps are charged to, lets say 240V DC 2kva, from the reverse don coils, is it useful to replace the MOSFETS for 240V 10A type instead of 60V 50A or voltage dividers?
Resistors as voltage divider waste energy!
Use a different transformer winding ratio for the input voltage to output voltage.
500w Modified Sine Wave Inverter Schematic Circuit Diagram
Best Regards
Hi,Originally posted by T-1000 View PostI just found quite important information related to topic(from Dynatron in 001-lab.ru):
I don't understand Russian. But recognize in the last video link the plate setup Don was demonstrating. Aren't they missing a charging cap for energy storage?
Very interesting!
Best Regards
