Originally posted by mr.clean
he puts in ?
The energy is greater because he accumulates it inside the system which is
not output. It is just activity, oscillating energy.
Counsel
Will you pardon me for interrupting again. You spoke some time ago about getting all of the energy from your transmitting into your receiving station by this method of yours. I do not understand how you can get all of it.
Tesla
Oh, that is hardly true; I am speaking as a matter of principle. You never can get all the energy, because there is no such thing as perfect apparatus.
Tesla
in because there will always be some losses.
Now, there is a vast difference between these two, the electromagnetic and current energies. That energy which goes out in the form of rays, is, as I have indicated here [on the diagram of Fig. 82], unrecoverable, hopelessly lost. You can operate a little instrument by catching a billionth part of it but, except this, all goes out into space never to return. This other energy, however, of the current in the globe, is stored and completely recoverable. Theoretically, it does not take much effort to maintain the earth in electrical vibration. I have, in fact, worked out a plant of 10,000 horse-power which would operate with no bigger loss than 1 percent of the whole power applied; that is, with the exception of the frictional energy that is consumed in the rotation of the engines and the heating of the conductors, I would not lose more than 1 percent. In other words, if I have a 10,000 horsepower plant, it would take only 100 horsepower to keep the earth vibrating so long as there is no energy taken out at any other place.
just to keep the Earth oscillating with no other power taken out at any other
place. After some time with no energy taken out from any other place there
would be considerable losses, and with no output yet.
That's 75 Kw idle power input. Go figure. And when there is power taken from
another place the input would increase to maintain the oscillations. It is
a 7.5 Mega Watt or 7,500,000 Watt system he is describing..
Just like this.
This is the circuit.
These are the measurements, the input is about 3.3 Watts continuous, I
measure oscillating power of 140 var and a peak power of 644 Watts.
There was no output when the measurements were made.
The energy within the system is much greater than the 3.36 joules per second input.
And this is a scope shot from the same setup but not for measurement this shot was taken from the mosfet drain (coil negative to circuit ground)
Yellow trace is the primary (direct connection).
Blue trace is the secondary from a remote probe about 400 mm away.
The damped wave is of advantage because it gives you, with a generator of 1 kilowatt, an activity of 2,000, 3,000, 4,000, or 5,000 kilowatts; whereas, if you have a continuous or undamped wave, 1 kilowatt gives you only wave energy at the rate of 1 kilowatt and nothing more. That is the reason why the system with a quenched gap has become popular.
Farmhand your grouchy
, I hope we are on the same team
