Originally posted by hotrod68r
You can power it with an ordinary signal gnerator, so it is a fairly easy project to build and test with. The tricky part is getting the two coils very close to the same resonance frequency. When I can find the time, I want to try the experiment again using pancake coils, and I want to test the effect where this type of power transmission can apparently pass into a faraday cage without any problem to the receiver coil. I think it is interesting as well that on Meyl's device he says the longitudinal wave transmission effect occurs at the second resonance point at around 7 MHz, but apparently it doesn't work the same at the first resonant point around 4 MHz or so.
im guessing you'd want to use the highest input DC voltage possible to keep any heat down.
