Hi ilandtan,
first, my nst's arrived. i ordered two same freight cost for one or two. both appear faulty! will not run properly. what i do have is a couple of HR208 flyback transfomers, no diode built in. it has been raininng heavily here so no work on the house. i have put my figueras device on hold while i work through the theory more slowly. i still cannot get past some sort of radiant effect is needed for the massive output. time will guide me.
i am back on the Don at the moment trying to rationalise the electret theories. i have ordered some machining for a reusable mould for the canaubra wax as a short term fix. all my polymer tests have ultimately returned either positive or negative homocharges, which i think has to be material related. however it is possible that i should build a corona discharge cabinet as this might be a better solution for the polymers, or so the related information suggests. homocharges look to be more difficult to harvest, requiring contra voltage to charge for performance. ok in microphones where it is low level voltage.
i will look for a plasma globe and start this test. i had wondered about the coil and its Rx/Tx. will keep in touch when a globe surfaces.
regards
dwane
regards
dwane
That's twice as strong as mine!. I have 34 uT for 34Kv. You see what we could do with a slayer coil (mine measured 5 uT) putting out 1/7th of the flux of my globe, and 1/15th of your globe. Imagine if we can translate that to power to ground like we do with RX slayers.
