Gravity - just pure plain GRAVITY
  • Outsmarting Aether is a Jui-Jitsu problem.
    Basically to me it's an application of
    • Opposed Halves go into OverUnity it would need to be spinning @earth-equiv speed 1st
      We need to keep always in mind
      Last edited by CloudSeeder; 12-12-2009, 06:46 AM. Reason: when an object/planet is spinning it's adding to the horizontal mixing of basically straight incoming radiations.
      • Not necessarily exact copies (the halves)
        This dual-opposed direction of spin probably wouldn't
        • Sector-Partitioned Spinning Record Dialectric Platters = Magnetic Field Pulse-Plasma:
          how the capacitor could operate as an
          Last edited by CloudSeeder; 12-12-2009, 07:26 AM. Reason: Momentum of the platter should impart enough inertia to counter and overcome any attraction-slowing problem.
          • Just been studying a vortex. Could the earth, and all spinning masses, be behaving as a vortex? Spinning heavier air and water toward the upper reaches of it's limit, while at the same time drawing lighter air,gases toward it's center? After a while it would have to equalize, causing it to expel material(volcano), thus throwing out lighter gases which it had accumulated. Also could cause some effects of the phenomena we call gravity. Is it possible that a vortex could be produced by a spinning solid mass? Maybe there is more to gravity than just a single centrifugal force, centripedal force, or even a ionic force. Maybe a combination of joined forces working to make one detectable force. Just a thought. Good Luck. Stealth
            • Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
              • Spinning, Vortex and Gravity
                I would dare to say "Negative'
                Yes, spinning will put heavier matter on the exterior and lighter matter to the center; but in the issua of the universe such is just the opposite. Heavier matter is to the core and lighter matter to the exterior.
                In general it has been found that spinning/rotating objects do produce some anti-gravity results. Just about anything you can try with, spin it fast and it reduces weight, if magnetized it actually reduces a higher percentage of weight.
                Thus I would accept the possibility that a spinning device does reduce the pushing effect of the aether since it somehow re-directs some of that aether sideways. This is something that would need much more thinking and experiments - one which I am presently preparing in my bedroom - to the dismay of Ms W.
                • Axle ends have a float ball and in water you'll achieve near-weightless of the disk.
                  Let's just say you made a
                  • ... producing a killer thrust. Light Speed to Be There Speed.
                    about the aether-using spacecraft being able to get its
                    • Resonance
                      RESONANCEFREQUENCY COILS:
                      • Inductance Calculator
                        Here's the bit I can help with;
                        Pronine Electronics Design - Single-Layer Air Coil Calculator
                        The aether as I understand it, as the massless medium, has not really been verified other than here:
                        YouTube - Extended Michelson-Morley Interferometer experiment. English version
                        Frequency of transmission in the medium? I don't know. Broad spectrum - how fast is a wave in the ocean, how long is a piece of string?
                        How fast does the aether attempt to re balance an imbalance (magnetic or static field collapse)? Immediately.
                        • Resonance of Aether? our visible universe overlaid over what was already here.
                          Since we can't hear aether it may not have
                          • doing a tree and the sky paint fills itself in.
                            the sky ............................
                            • The aether is in another dimension which we can't interpret. We can only identify matter in 3 dimentional context. If we are to study aether, in all it's complexities, we must find a way to bring a 4th dimention into our 3 dimentional reality. Only then can we realize what aether really is, and how it reacts to matter in our 3 dimentional world. Aether must have the ability to cross all dimentions of space, matter, dark matter, and every thing in between. Until we can devise a device to intrepret these other dimentions, I'm afraid studying aether is out of the question. Good Luck. Stealth
                              • can't see it doesn't mean we can't write an equation for it.
                                Just substitute energy for
                                Last edited by CloudSeeder; 12-12-2009, 07:27 AM. Reason: Equation: Just pencil something in and call it the variable for invisible.
