I am glad to see all the interest in gravity, although all we have so far about it is just theory. Some really good theories have been presented here. Whether gravity actually causes vortexs, centrifugal forces, or repel magnetic forces in the space fabric, one thing we can agree on is that it is a real phonomena that is not easily understood. We can't see it, touch it, taste it, or feel it, but we can surely feel the effects from it. When I think of spinning masses, I think about comet Schumaker breaking up into pieces and slamming into Jupiter. That was a strong gravitational force at work, with enough power to break up a comet into pieces. If we could harness that energy, we could supply power to our entire planet. Whatever it is, it pulls or pushes everything towards the center of our planet. Maybe that's all we need to know to use it as a power source. Build a motor to harness that energy, and reset it's own weight. I have been working on one and I am close to perfecting it. Good Luck. Stealth
Gravity - just pure plain GRAVITY
generate enough electricity in 15 minutes to run a home all day long:
mvjdhgieudjfLast edited by CloudSeeder; 12-12-2009, 07:13 AM.
Gravity as swirl in moving water
If we analogies the outer space as huge river, a gravity is a water ripple that create swirl. The swirl can either make the fluid going in or going out the rotation. Heat/energy transfer also happen during this occassion. Solar system rotate in galaxy swirl, planet rotate in solar system swirl with sun as center, moon rotate around earth, people rotate around earth.
In this theory, gravity happen because the huge outer space river swirl force any molecule to go along the flow. In earth the flow also goes to the center, where lighter molecule (plasma) collected at center. Heavier things tend to stay behind.
A black hole happen because the erruption of star cause enough fluctuation in the fluid that anything including light got absorbed because the fluid trying to regain it's place, just like exploding in fluid where the highest force happen when the fluid try to get back to where it's belong.
Sun energy, earth energy, man technology is nothing compared to the swirl of the huge outer space river. Heat, matter, light, sound all also move along with this river flow. But just like a trout that can stay in one place without doing anything in fast flowing water, we should be able to move freely in the huge outer space river too, if we know what the condition required.
There is no need for earth gravity to tie the moon to prevent it from escaping, since the moon is moving inside the earth swirl. Since the moon always show the same face, the moon it self do not experience swirl inside earth swirl.
When some outside object entering solar system swirl, it got affected by the swirl of planet, moon or sun. While the solar swirl or planet swirl is unaffected, it may change the course of the outside object. Just like a leaf following the river flow, it may attracted to swirl and never get out before it sinks.
Planet may collide if the swirl merge into bigger swirl. It won't confront each other from opposing direction but rather move into designated common location. This way a planet may join other planet as it's moon if it's swirl is smaller.
Just like in a river, there are places that has non moving fluid, either seen from people in the side of the river, or seen from fish moving along with the river. In earth we are the fish, In other galaxy we are the side viewer.
Rotation of the moon to planet is opposing or the same as rotation of planet to sun?
propulsion
Aromaz,Originally posted by Aromaz View PostI have thoughts in the similar direction. But rather than a shield, would think of a closed loop electronized gas flowing in defined and controlable directions - within the shell of the hull and such then 'redirect' the radaint energy around exterior. i.e. the hull of such craft is a double hull with example mercury vapour flowing from forward to back; this will create a flow of ions in same direction near exterior of craft - ionic wind - vacuum in front, pressure on back. As for the craft; complete closed circuit propulsion system.
This is almost identical to what I proposed in my book is a shielding technique...or actually a deflection of the aether around the shell utilizing ultra high frequency and voltage to create a polarization instantly of the "ambient" aether as the ship touches it.
The positive charge is pulled to the rear of the shell of the ship causing a pressure from behind while there is a vacuum at the front, in the true sense of a vacuum lacking even the aether.
The ship is then not simply pushed from one spot to another but sucked with negative resistance through the aether.
If the aether is deflected around the ship instead of through it, there is no inertia.Sincerely,
Hi Aaron,Originally posted by Aaron View PostAromaz,
Sorry, but the vacuum without Aether is still something. We don't know what the Aether is, or how many types of Aether there are. How Aether is related to inter-dimensional travel. Just as I have understood, that we don't need to find ways to omit inertia for interplanetary travel, because it would be so difficult to control a ship without inertia. It would zoom out and disappear in deep space. Of course it would be useful for abrupt changes in speed, without the passengers knowing it.
What we want to learn in this case is how to travel hyper-dimensionally, or by creating a wormhole for example. If we understand what "space" is we don't need to travel, we need to change the "space" of our ship instantaneously.
Elias
I think that Aether drift = Inertia, Aether flow = Gravity.Originally posted by Inquorate View PostAether drift = gravity.
And a spinning disc, may decrease the effect of gravity, because it would cause the flowing aether (gravity) to be spread out in some fashion.
How insects defy Gravity?
Hi,
Something that I have been thinking lately is about insect flight which has still remained a mystery in conventional science. Aerodynamics cannot explain how a bee flies? Remember that this conventional science did not believe that even an aeroplane can fly about 100 years ago, and the Wright brothers made them believe that it is possible. So how do insects fly? With such small and fragile wings? There has been attempts to explain this by conventional means: Scientists Finally Figure Out How Bees Fly | LiveScience
But it is too funny, that they are still trying to somehow fit bee flight into mainstream science, instead of extending science by finding out how they fly!!
They even used a less denser air (composed of oxygen and helium) and found out that their flapping frequency did not change! And thus concluded that the bees must be "stretching out" their wings!!!! I wonder how much can a bee "stretch" its wings?
This still does not resolve the problem "How such small wings, without any aerodynamic features" can make the insect fly"?
How can a simple fly make those sophisticated manoeuvres in the sky?
Anyway, my personal opinion is, if the bee did not require breathing, its mechanism of flight even would allow it to fly in a vacuum, containing the Aether alone. Because I think it is a type of Aetheric flight instead of Aerodynamic flight.
Elias
ship controllability and vacuum vs plenum
Hi Elias,Originally posted by elias View Postthe vacuum without Aether is still something.
It is literally, a vacuum not the commonly misused term vacuum, which does contain aether. Plenum should describe space filled with aether because that is accurate. Literally, vacuum is a lack of even the aether, which is literally a void of nothing.
It is a negative pressure or suction and is lacking any positive potential at all...only negative. Light is unable to be transmitted in that area.
The positive potential that has been strongly removed from that area by strong broken symmetry by the ultra high voltage difference to cause a negative pressure zone is trying desperately to dissipate it's own potential by getting back to equilibrium.
The problem is that it has grabbed a hold of one end of the shell, which is forced be pushed in the direction of the void and at the same time, the void is pulling the shell into it but it can't reach equilibrium as long as the potential difference across the shell is kept.
It is highly controllable. And directionally can be done by simply moving the reference points of the positive and negative voltage difference to different areas of the shell. Up, down, left, right, front, back and any combination.
A lot more is known behind the scenes than what you might think.
A lack of something is not a something in itself - could be semantics or philosophy but... consider these...
Cold is not a something, it is a lack of warmth.
Dark is not something, it is a lack of light.
The negative pressure zone isn't a something, it is a lack of a positive something.Sincerely,
propulsion
This is exactly what my explanation allows for when it is understood.Originally posted by elias View PostIf we understand what "space" is we don't need to travel, we need to change the "space" of our ship instantaneously.
TRAVEL implies moving through space, which has depth, height and width. It has a distance component to it. It has the ability to transmit visible light in the em spectrum.
In the suction of the negative potential created at the front of the ship and having the aether slip AROUND the ship instead of through it, any movement from one point to another is instantaneous to the pilot. No time can pass where light cannot travel.
That which makes up actual "SPACE" is lacking in the negative suction. It is having space slip around the ship.
This is what subspace literally is for "traveling" purposes.
The stargate movies/shows all came from consulting with a govt trained remove viewer. That is your worm hole concept but it isn't needed.
Imagine that the pilots in the most advanced craft are utilizing their consciousness to tell the ship where to go as there is a connection between the ship and their biology and mind.
Anyway, just a few ideas.
Negative on any rotation. I presume there will be no moving parts whatsoever except the the internal gas booster. The hull and all external parts are closed, sealed, solid and stable. Only the gas will flow within the hulls, causing transmitted effect to the exterior.Originally posted by CloudSeeder View PostAromaz: So if the double hull, the outside one has regular slots while all that you said is rotating inside encountering the shadows... plus the both of them together are also in a fast rotation you would then establish a pulse force, pulse drive?
Theory based on soem experiments I did with my DRE in video 23-25 - before I packed my lab up for moving.Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
Sounds similar! I asked you very long time ago for books and gave budget ... See how much time you might have saved me!Originally posted by Aaron View PostAromaz,
This is almost identical to what I proposed in my book is a shielding technique...or actually a deflection of the aether around the shell utilizing ultra high frequency and voltage to create a polarization instantly of the "ambient" aether as the ship touches it.Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
