@ Cosmicfarmer.Hi.interesting experiment you have going on there
With regards to your joulethief.Jeanna who championed the secondary on a joule thief idea has done extensive tests and found like you that an led in the oscillator circuit is detrimental and better to place them in the secondary circuit but i would try leaving the secondary open like you suggest with an avramenko plug on each end.Put you Leds here and on the last led negative lead,have a croc lead going to an aluminium tray as a virtual ground.i have had good results with such a setup.Thanks for posting.Regards jonny.
David
Btw the wireless video you posted is very interesting, and the fact you can light the neon off that coil even with it loaded down with the leds, is amazing.
I added a second transistor in parallel to see if that helped. It didn't seem to increase the output as I had hoped but it did help carry the load and prevent over heating.
