Well what I do know is it cant be more than 24 volts because thats all this modified computer PS puts out. I'm looking forward to seeing the amp draw for sure. One note in all the experiments I have done with the TIP35A I have never had an issue with hot transistors. I'm still using the same transistor I originally installed when I but this setup together.
new vid
This is a video using the IRF510 MOSFET with one 1.5 volt AA battery (in cell phone charger).
YouTube - Slayer exciter IRF510 at 1 5V
Good work Xee!
Thats pretty similar to my output when i use a phonecharger and 1AA - but I can get three CFLs prety well lit if i use my stainless steel pasta sieve and aluminium toroid as a topload. Have you tried a topload? It seems to help the output and increase the field volume.
Keep em coming!
TIP 35A on the shopping list.Originally posted by Jiffycoil View PostWell what I do know is it cant be more than 24 volts because thats all this modified computer PS puts out. I'm looking forward to seeing the amp draw for sure. One note in all the experiments I have done with the TIP35A I have never had an issue with hot transistors. I'm still using the same transistor I originally installed when I but this setup together.
What resistor do you find best for this transistor?
Thanks Jiffy - good luck in your next experiment with the sexy exciter.
Hi Buggler - there are great links left by JonnyDavro in post 1 page 1.Originally posted by bugler View PostSorry to interrupt the dialogue.
Where can I find a detailed explanatino about this joule theft thing?
Thanks.
We are chatting about the exciter - it seems to have had more attention than the joule thief on this thread. They are 2 different (but both very interesting) circuits. The simple slayer exciter is the circuit that has received most attention here. Its confusing cos dr stiffler did a lot of work with similar circuits and called the process ''spatial energy coherence'' or SEC for short, and the Russian tinkers on ru.tube talk about a ''kacher'' or 'brovin generator'' which is also very similar in circuit design. The exciter is composed of two oscillating coils which are driven by a transistor - some people call it mini tesla coil (though it has no capacitor and no spark gap) because its effects are rather similar....plasma, wireless transfer....etc....
Im of the opinion that the reason they are both similar is because they both produce standing waves. Im still trying to come to a better understanding of them.
But generally i prefer to experiment first and come to conclusions later....so more work has to be done! Should get some free time tomorrow when the baby is at kindergarten.
Another charging approach
@ Slayer and All
I did a little experiment today with a different charging method and made a video of it. Basically I pulled external energy off the Slayer Exciter source battery case through a capacitive link and an AV plug then fed it to a AA running a pulse motor. No big deal except that there was more power there than the liitle pulse motor needed. It made the amp meter show a charge instead of a discharge . I love it when that happens---which isn't often.
YouTube - Slayer Exciter charging a pulse motor.ASF
Lidmotor
Hi guys,
Has anyone had any joy trying out MOPOZCO's 2N3055 circuit.
I must be missing something, cause I can not get this thing to oscilate.
I am unsure from his youtube, if it is 50k or 5k going to the base from +ve.
Should there not also be a cap there somewhere.
Wonder where the large cap near the power supply fits in ?
Any help appreciated.
Kind Regards, Penno
Sorry guys, I should have stated - MOPOZCO'c TROS "aircore" !Last edited by penno64; 10-16-2010, 05:09 AM.
The amplitude of the voltage spike when power is removed from a coil is a function of the rate of change of the current. This is one of Maxwell's basic equations from a long time ago. Unless I am missing something, this is all that the video is showing.Originally posted by penno64 View PostHi guys,
Kind Regards, Penno
Mini Slayer / Mopozco SEC
Hi PennoOriginally posted by penno64 View PostHi guys,
Kind Regards, Penno
ps chk my post 1167 only smaller version of the coil at 50 ma
cheers
totoalaas
Thanks Totoalas,
"With 2n3055 (warm) 1 mohm R l2 18 T 18 awg solid inside L1 30 awg 8 1.5 inches"
Is that
Resistor - 1 Meg Ohm
L2 - 18 Turns of 18awg
L1 - 8 x 1.5 of 30awg
using around a 150k ohm i can get it oscilate if I touch the end of L1 or connect to length of wire.
My arrangement is
L1 - 10 x 1.5 inch of .3 mm
L2 - 10 turn of .63mm on 3.5 inch diameter
Resistor - 150k
Kind Regards, Penno
layer/ Mopozco Sec
PennoOriginally posted by penno64 View PostThanks Totoalas,
Is that
My arrangement is
Resistor - 150k
Kind Regards, Penno
jut 1 meg om base to pos rail no more cap( basic slayer) this is the best since the 2n3055 will not heat up and stays warm
of course the 14 inches tower will produce the plasma as shown by Mopozco
L2 18 turns 18 awg mag wire inside of L1 core
L1 8 in height 1,5 in dia 30 awg
if you add a pf cap in L2 the output decrease
cheers
totoalas
