Carlos Benitez
I've used mercury switches with the Bedini circuits that was triggered
by a lobe on a pulley that comes around and thumps the mercury switch
that caused the caps to discharge into the charging batts. Works just fine
but I like copper contacts better.
The Benitez circuit works. It is similar to the Tesla Switch in concept.
I independently developed some circuits about 7 years ago that I later
found were almost just like Benitez in concept.
In the Tesla switch, do you see the load is connected by 2 grounds of
different negative potentials and they have a common positive?
The difference between the negatives can power a load with no voltage
but all the benefits of amperage, cold amperage. If you use the wrong
frame(s) of reference, you won't get it. In splitting the positive you have
common ground with a positive potential difference.
Originally, after learning of the concept of splitting the positive, it was
a common sense deduction to look for splitting the negative. That isn't
completely what is happening but that is how I stumbled upon my own
circuit variations that take advantage of the concept in the paragraph
above.
above.
