Hello Everyone,
I was wondering, why don't we make coils with copper or aluminium foils.
Making coils with foils can make the coil more compact and efficient without any gaps, and with much less resistive impedance. I don't know if I can find coated foils somewhere, or I need to insulate the layers by using tape.
Consider making a coil by using a coil with a copper foil of thickness of about 0.1mm and width of about 50mm and about 300 turns, about 50 meters, which will result on approximately 0.15 ohms of resistive impedance, which will highly increase the efficiency of it, especially for charging Bedini Circuits.
Normal Aluminium Foils have a thickness of about 0.01mm and are too thin, but even with them one can build a coil of about 1000 turns and 10cm height, and a core of about 10mm and whole diameter of 30mm which is very small and light, but with high inductance and the resistance would be only 2.6 ohms.
This is one source I have found that makes these types of coils: Jantzen Audio Cross Coil copper foil
Any suggestions, or comments?
Elias
Elias
