Here is the salt water after some use with the gunk settled on the bottom:
These are my end caps with the magnesium rod fastened to them:
This is how it will look like when the outer stainless steel tube will be attached:
I have all the steel tubes cut to size, now I need to weld some threaded steel rods to them that will go through the plastic end caps like this is done with the magnesium rods. The magnesium will be easy to change this way
Thank you!
Jetijs
Thank you!
Jetijs
This is what is called milk magnesia. Also it is a great isolator and great fireproof material because at higher temperatures it releases water and turns into magnesium oxide. And magnesium oxide is also great fireproof material and isolator
