Free Energy Generator- The real deal!
  • #16
    Hi ashtweth, not sure what you are trying to say. I only named the title like that because that was his video title. If you mean open source sharing will get this to all the people of the world, well thats up to the people i would say, but i hope your right. If enough dont wake up and stop towing the line of the same old crapola in this world, the masses wont even know this website existed. I've been researching this energy thing for 10 years at least and this seems more about something spiritual than people getting a simple excess energy device, the devices i think do work are probably childs toys comparatively to our real potential, meaning if we grow up we probably dont even need these tinker toys, though ill take one for now and anyone else that wants one, lol. I ran a simple test based on that last drawing i posted and it seems to work, i rotated 2 neo magnets with motor and placed it above a rotor with one shorted coil and it resisted the coil then repelled it and when the coil rotor is spun by hand slowly the load drag diminishes, though with more coils on the generator rotor to make a more continuous output would be a better test to see if lentz load drag can be relieved without losing output. Few thoughts.
    peace love light
    Tyson
    edit: yes i thought about that yesterday, the spring action you mention, because it does seem difficult to get the disc magnets to rotate, so the bouncing of the magnet may be a better explanation.
    • #17
      Tyson, you have done well and thanks for posting my friend. We have enough of the war brothers here who are intent on quelling subjugation to help validate this between us there is no stooping, us, I just wanted introspection in relation to title to reflect the direct status of the project , i guess you mean well my friend. Let have a closer look . Note AARON, GLEN, ROSE, and HARVEY are the real deal with the RA circuit. Ill have some rep data for all on that soon.
      Ash
      • #18
        Hi marxist, thanks for your reply and evaluation of Wendell's device. You may be correct that it may need the spring like oscillation of the mag lev principle to function properly, because from my simple tests it seems difficult to get them to spin. Now what is interesting, is that as shown in my last drawing, that if we were to cause enough of a lentz effect in coils mounted on a separate rotor that is free spinning. So as long as this separate generator coil rotor is moving in a direction opposite to main magnet rotor then lentz load reflection back to prime mover is reduced if not eliminated. I've never seen any other generator rotate the stator coils in opposite direction like this, so either a 1 to 1 belt drive setup to connect the 2 rotors or a separate small motor for the stator rotor, whichever works best. The thing i see different here from a typical prime mover turning a generator, is that in the typical generator the magnet is resisted on approach to coil and wants to pull back to coil on departure. Where as in my tests with my last drawing which is what i came up with, not the one that this thread is based upon, is that when the motor is turning the magnet rotor and if we rotate the stator coil rotor in opposite direction the magnet is resisted as usual, but it then repels or pulls the coil along tending to move the stator rotor in opposite direction like gears, which relieves the lentz effect. Just a few thoughts. Thanks for your comments Ashtweth, your doing good work, dont let me distract you. Unless you see something that looks workable.
        peace love light
        Tyson
        • #19
          providing the force and condition to rotate the magnets
          Hi SkyWatcher,
          ....it does seem difficult to get the disc magnets to rotate
          I tried to rephrase and edit my previous posting in order to stress a particular point.
          Namely the size and position of the coil(s). I think this detail of the construction is very important. More important in my opinion, than the vertical bouncing possibility for the magnets.
          Maybe you can do a test and will find, that the magnets will rotate more easily, if the position (i.e. axis) of coil and magnet are aligned as in Wendell's device and as described in my revised posting (see above). If my description is not understandable or makes no sense, I will try to describe it better.
          • #20
            Can't seem to recall what is the RA circuit Ash is referring to. Can anyone enlighten me?
            Skywatcher I think you may be on to something here. Best of luck with this.
            • #21
              Hi marxist, you may be correct and i dont doubt his device works as claimed, its just getting neo magnets of ring type is difficult and probably expensive. That is why i'm thinking up a similar way to achieve similar results. Does anyone else know of a generator that allows the stator to rotate freely or actively rotated, because i have never seen it.
              Hi ewizard, the RA circuit is Rosemary Anslie's heater circuit, her handle is Witsend. Thanks, i hope i'm on to something, since it seems different to anything i am aware of, aside from Wendell's device. I'm going to focus on my design since i have magnets better suited for it.
              peace love light
              Tyson
              • #22
                Plan Replication
                Is planning to replicate this device.
                • #23
                  I am waiting Experiment results
                  Hi SkyWatcher
                  Very concerned about your experiment, I am waiting for results.
                  Xu Yuan
                  • #24
                    This device may be produced miracle
                    In fact, this device is the key: magnetic bearing! in This device is the real self-running overunity? has a post discussions, many people don't care about this device because it looks so simple, in fact, the structure is not simple. If you carefully study will find: this device can greatly avoid friction, gravity, Lenz, so this device is very likely to achieve self running, it may also produce extra energy.
                    • #25
                      Hi yx630514, thanks for replying. I set this project aside for the moment, im working on a device similar to something Don Smith came up with in the thread call bloch wall shifting generator. I started this particular thread because i think this device might work well if built so that the rotatable disc magnets rotate easily enough so as to not slow the rotor when lentz effect occurs. The best way to know a truth is to find out for yourself, if you can, and build this device and see for yourself. I may be returning to this device to make a better model, since it is a little tricky to build it properly as shown in his videos.
                      peace love light
                      Tyson
