One ring to rule them all
  • #16
    Dit some minor testing.
    It seems that the volume of air > out of the explosion is almost equal to the volume of air < in the explosion.
    Out > YouTube - HHO 10
    In > YouTube - HHO 11
    • #17
      First shooting ;-)
      Althoug it seems not so powerfull with the balloons. The force is very strong.
      It is not a hughe amount of air, but the speed is very high.
      Here i schoot a plastic cap of the hose.
      YouTube - HHO 12
      • #18
        First closed loop test.
        Valve system seems to do its job.
        First notice: After the closed loop explosion there seems to be underpressure.
        YouTube - HHO 12
        • #19
          YouTube - HHO 14
          • #20
            Testing a home made valve.
            It's a 2 Euro coin ;-) With some tape.
            I put the webcam in the tube.. Seems it is not perfect yet! ;-)
            YouTube - Valve 2
            YouTube - Valve 3
            • #21
              The problem i see with your setup is it can work for a small amount of time but when the magnet will become hot, the magnetic field will reduce until there no more magnetic field so the reaction will stop, how will you solve that problem ?
              Best Regards,
              EgmQC
              • #22
                Best Regards,
                EgmQC
                Hello EgmQC,
                Well i understand what you say. I'm first gonna try the principle.
                But to adress your remark at first hand:
                One option is to seperate the hot air from the trajectory, with a free piston it might be possible. But not prefarable, it would involve more parts... On the other hand.. I do have engenering challange with the middle valve.. it could be joined.
                Another might be cooling the tube by submerging.. anyway.. Cooling ribs?
                Well not there yet.. Any input appreciated!
                • #23
                  Another thing ill worry a bit is the copper ring, he will slow down your magnet so much that almost not power will be induce in your coil, its like a motor with all coil shorted , if you look at the equation for the amount of energy you can extract from your coil , the velocity will be really low since the interaction from the copper ring with the magnet will fight each other. Do you have found some solution for that one too ?
                  Best Regards,
                  EgmQC
                  • #24
                    Best Regards,
                    EgmQC
                    Well I think you misunderstood
                    The copper ring is outside the system.
                    I post a pic.
                    • #25
                      Originally posted by Cherryman View Post
                      The copper ring is OUTSIDE the system.
                      That change nothing , there will still be a interaction from the magnet and the copper ring, throw a Neo magnet in a copper pipe , you will see the effect, it slow the fall.
                      • #26
                        I know, Lenz. The distance is variable so i don't see a problem yet.
                        Well i even gonna try to shoot it trough a round copper pipe!
                        I deal with the challenges when they appear ;-)
                        • #27
                          There a video on youtube who show a demonstration, i dont have the link but im sure someone will post it, it show the difference between a non magnetic object and a magnetic one in a copper pipe, the non magnetic one took less than 1 sec to go from the top of the pipe to the bottom and the magnetic one (he used neo magnet) took about 8 sec
                          • #28
                            I didnt found the one i wanted but i found a similar, look at this one YouTube - magnet copper tube
                            • #29
                              Yes i know that, there are we even a few more. It's the Lenz effect.
                              I hope to use that to generate someting... anyway.. fun ahead ;-)
                              Edit: Yes.. that resistance in de video.. , well i think shoot a magnet trough and you might get a surprising kind of current! ;-)
                              • #30
                                My last one, more visual.
                                YouTube - Eddy Current Tubes
                                Best Regards,
                                EgmQC
