Hello Everyone
I have built and tested numerous setups and also have Ricks 3-pole kit. I have always used car batteries that I rejuvenated using the Bedini circuit but have had trouble getting the batteries to charge up past 12.50 volts only using 12 volts of input until now. I am now able to charge 2 car batteries in parallel to over 13 volts with 12 volts input using Ricks 3-pole kit with a few modifications.
First I mounted the bifilar coil on the top center location where the generator coil usually goes and the 2 other drive coils are located where they normally are. I am not using the generator coil at all. Now take only 1 Bedini circuit and wire it up to the bifilar coil like normal. For the other 2 drive coils parallel their wires with the bifilar drive coil wires but reverse the wires so that the coils will fire in attraction mode. So now you have the bifilar coil firing a north pole field and the other 2 coils firing a south pole field. 1 coil pushes and the other 2 pull, all on 1 circuit (1 transistor).
Instead of using a 1n4007 I hook up a FWBR to the drive coils and eliminate the wire going from the positive of the run battery to the negative of the charge battery. I use a 470 ohm resistor and a 1k pot on the trigger base. Give the rotor a good crank to get it going and SLOWLY turn the pot (can take a good minute to get up to speed). When the rotor gets up to 5,000 rpm I bypass the pot and use just the 470 ohm resistor and the rotor speed increases to a little over 5,200 rpm.
This has resulted in the best charging I have ever experienced with 12 volts input. The input amps hardly registers on my 5 amp meter but pegs my 100 milliamp meter so its around 150 to 200 milliamp draw.
Mark
Mark
