gravity waves found
What I find interesting is that floating block filling in J1 to K6 just barely setting on one corner there hanging out in the air like that.Originally posted by Adie123 View Post
Originally posted by Jetijs View PostInteresting thoughts witsend
Jet Hi. Do you think the depth of that 'rose'? or should I call it a clover? - do you think that goes through the entire depth of the rig to 'line up' with the legs or do you think it's sitting on top of the rig? I can't for the life of me tell which.
witsend, it is sitting on top and does not go through, that is for sure. Also someone mentioned to have seen a picture where the bottom part of the wheel was shown and there is also one such clover. If that is true, we have two of these, one on top and another on the bottom side of the wheel
Thanks Jet. Very much.Originally posted by Jetijs View Postwitsend, it is sitting on top and does not go through, that is for sure. Also someone mentioned to have seen a picture where the bottom part of the wheel was shown and there is also one such clover. If that is true, we have two of these, one on top and another on the bottom side of the wheel
Hi guys Im kinda out of my league here but Ive been reading and trying to understand this real hard. I came across a book that they say is a coded message left by Edward as a gift to us. That in fact he left clues and hidden things like this everywhere. The book is called "a book in every home." Before I knew that it was a puzzle I thought that it was written funny. Just the way he describes some stuff in there. I cant hardly believe that he would put out a book telling how a girl should look or behave and how she should be made up. But if you were thinking about a machine then things sound better right from the start. I think he gives us verbal blueprint for this device. someone check it out if they havent already.
Special fixture
@ Harvey, In your picture with the green writing you have pointed out several interesting features. Most of them I had not noticed. Thank you. The feature you pointed out as a special fixture welded on at the bottom of the rod cap I believe is not a special feature. It looks just like a normal dipper that was a part of the rod caps of that time. All automotive engines until the early fifties had a dipper on the bottom of the rod cap. This had a small hole in it that went to the crankshaft journal. As the rod rotated it dipped into the oil and oil was forced up through the hole and onto the crankshaft journal to lubricate the bearing surfaces.
I am trying to figure out what the rod could be for. Does anyone know what parts of this machine rotate and what parts remain stationary? I was under the impression from the pictures that the whole thing all rotated together with the crankshaft below it. If so I don't know what the rod dipper would be for. However it seems like the rod dipper is pointed to the V of one of the magnets and maybe it somehow stays stationary while the magnets move past. From what I have read about Ed, I don't think he put the rod in there without having a reason for it. Only more pieces to the puzzle I guess.
CarrollJust because someone disagrees with you does NOT make them your enemy. We can disagree without attacking someone.
Carrol, you are right, everything rotated together, everything inside the wheel rotated along with it. We must also consider, that Edd used what he had at hand and some things there could be not necessary, he just used what he had. But one thing is certain, the clover piece was put there intentionally.
Ive got a feeling that the clover bowl was just something used for extra clamping of the plates and magnets. I maybe wrong though, but thats what it seems like to me at this stage.Always thinking outside the box!
ASUS M4A87TD motherboard
AMD Phenom II x6 Turbo Core 2.8/3.3 Ghz Overclocked to 3.5 Ghz CPU
RIPJAW 4GB 1600Mhz DDR3 Memory
Gforce 9800GT 1GB Graphics
Windows7 64bit OS
20" LG LCD 1680x1050 Monitor
I heard about this but have not seen the book. Is there an 'on line' version? I understand that one of his advices was to keep female children small by underfeeding them. Seems bizaar. If there are encryptians in it - which I've also heard - then I'm not sure that the code is cracked - albeit I've seen something on numbers. But - as a solution - it really just leaves one with a whole avalanche of questions. But I'd quite like to read the book.Originally posted by redrichie View PostHi guys Im kinda out of my league here but Ive been reading and trying to understand this real hard. I came across a book that they say is a coded message left by Edward as a gift to us. That in fact he left clues and hidden things like this everywhere. The book is called "a book in every home." Before I knew that it was a puzzle I thought that it was written funny. Just the way he describes some stuff in there. I cant hardly believe that he would put out a book telling how a girl should look or behave and how she should be made up. But if you were thinking about a machine then things sound better right from the start. I think he gives us verbal blueprint for this device. someone check it out if they havent already.
CAnt find a full online version of the book. But Google books has a large limited preview. It has many pages. Go to google, under "more" tab click books. Type in Leedskanlin and click on one of his books. Others in that area come up. Find "A book in every home". The title itself may be a code. It doesnt fit into what he was talking about in the text either. One of the pages in particular talks about a smiling mouth. Almost seems as if it hinting at how to build the generator in a general way. Talks of teeth, and how big to open the mouth when smiling. I also get a weird feeling that he is somehow talking about growing crystals. He talks of nurturing and growing. And what they should look like. The sweetsixteen he is talking about is talked about on various sites. they say he is not talking about a girl but of sacred geometry. If he is not talking about his science then this is just the strangest book in the universe. The whole book seems as if it is an anolgy for his science. References to the Freemasons are alluded to. "Magnetic Current" may also be a coded book. This man may have very well been a genius and set out these clues for smart people to find and unlock his secrets. I would imagine that in his time if tried to go public with this knowledge the govt or even the masons who are very secretive may have come looking for him. So he put it in clues for us to find.
Hi redrichie
Thanks. I found it. Here's the link.
A Book in Every Home
Thank God for Scribd. The best invention since the written word.
Rosie
Read it through twice. Frankly I hope he IS talking in analogies. Else I'd be rather concerned about his general philosophies. LOL. I'm going to try a third read. One can substitute the sweet sixteen with a love affair for scientific knowledge - maybe energies generally - and that, at least, makes sense of some of his suggestions. But I can't really get to grips with the facial features and his general political views. Golly redrichie. One hopes he is really not saying what he appears to be saying. It would put him somewhere to the right of Genghis Khan.
EDIT Have done a third read and a partial fourth. I'm now absolutely sure that he is talking in cryptics. Else his suggestions would be preposterous. And I'm reading in SO MUCH MORE. Fascinating stuff. I wonder if you shouldn't perhaps start a thread on this redrichie? It would be an interesting discussion. I'm not sure it's appropriate here? Maybe Dave could advise us.
Harmonic Drive System! Please watch this demonstration on the inner workings of the Harmonic Drive, Harmonic Drive AG. Patent Number 2,906,143 which covers a " ... motion transmitting mechanism," listed the applicant as C. W. Musser. This makes Walton Musser the inventor of Harmonic Drive wherein he developed a new family of drive systems achieve high mechanical leverage by generating a traveling deflection wave in a flexing spline element.
Additional References:
Harmonic drive - Wikipedia, the free encyclopedia
YouTube - Harmonic Drive
YouTube - Genetic Algorithm, Friction Compensation
High-Speed Robot Hand Video
GB
