My video
presentation on accessing the kinetic properties of the aether, part 4 in a series of 4
YouTube - presentation on accessing the kinetic properties of the aether, part 4 in a series of 4
The 'textboook' comment by someone who's probably only ever built 'textbook'circuits..
User2718218 (3 hours ago)
You are missing a key point in your analysis. You are looking at the voltages only and not factoring in the current. When the transistor switches on for a short time, the current going into in the coil (which you are not looking at) is continuously increasing. So the ON pulse has quite a bit of total energy. Then when you pulse the charging battery you see that the voltage is higher for a longer time. You have to look at the current here also.
If you could make a timing diagram for the voltage and the current and power flow in the circuit, you would see how the energy is flowing through the circuit with respect to time.
The key thing is that during the ON pulse some of the energy is NOT flowing into the charging battery, it is being stored in the magnetic field of the coil. Then when the transistor switches off, the coil discharges its stored energy into the charging battery.
Suppose for example we say that the coil stores 100 units of energy. When the transistor switches off 98 units of that stored energy go into the charging battery and 2 units are lost in the recirculating diode as heat.
So you store 100 units and then return those 100 units less two units lost in the diode. This is what is really happening even though the voltage traces make it look like you have a longer charge time.
The circuit is not over unity.
My reply
Inquorate (10 seconds ago)
user271.. Etc does not understand that a battery can be charged solely with voltage spikes from inductive collapse, a la bedini charger. I've done the experiments, it works. he feels i ignored current, i did not. The battery develops it's own currents when exposed to electrostatic stress. This is how an electret can be used to charge a batte
ry.
Tv and school curriculums are destroying not just our children's futures, but also our children's minds.
My reply
ry.
