my smith kanapadz replication
Maybe not "new" but several different coil arrangements tested. Same NST set up with PFC cap as posted earlier, its driving a 100 watt bulb at 25 watts input at this point.Originally posted by bolt1 View PostAny NEW kapagens made this weekend?
I'm still having problems getting all into resonance, quite limited in my resources and I don't have alot to work with so I have to wind coils as close as possible using the caps I have.
________Last edited by dragon; 10-24-2014, 12:03 AM.
vrand and what it gives to you? i better stay in your eyes as idiot, because if somebody don't understand me, then what i doing here?
keep listening Don Smith and others who showing NOTHING - but he showing and everybody fall on that!
This is the same thing as McDonnalds - ewrybody know that this is garbage and deadly for imun system, but keep eating and dont understand why he is sick.
This device not helps to make world better - no way, it only destroys the Monopolysts.
Wars are over the world and its only increasing, and war is not for oils but to push somebodys EGO on other nations WAR FOR NOTHING, WAR FOR EGO
Think what you want. This is your and other choice!
Dragon, your coil is wound almost in right directionOriginally posted by dragon View PostMaybe not "new" but several different coil arrangements tested. Same NST set up with PFC cap as posted earlier, its driving a 100 watt bulb at 25 watts input at this point.
- show your windings.
P.S. The wires throught pipe not make sense - i dont know why Tariel is using it in that way, maybe to make it that way to connect wires easy - but as i tested, that not make sense. (This is not piont where make focus)Last edited by cosmo-lv; 06-14-2010, 02:50 AM.
So if Tesla used this idea to run his car then there is no ground needed in this circuit?Originally posted by cosmo-lv View PostWhen Tesla makes he FE device for car, then he say: "Energy comes from air"
Now i can explain what he mean by words "Energy comes from air"
Only what you need is little HV to make Born new electrons and lots of electrons forming around the wires, the second thing is to activate these electrons...
Think about it. And good bye!
P.S. if you understand this principle then you can reach Hunderts of killowats fith box around 200x200 cm
How could he have a ground unless he used one of those "grounding straps" that connected a car to the road. It was a strap that was usually placed on the rear end and hung down and dragged on the road, to ground a car, to lower static noise on the AM radios.
Thanks for any guidance here.Don
Nice thread. This is probably old news but heres a link of interest.Make: Online : 1000+ Fluorescent lights powered by overhead cables
Interesting thanksOriginally posted by Vickers View PostNice thread. This is probably old news but heres a link of interest.Make: Online : 1000+ Fluorescent lights powered by overhead cables
The Kapagen is a little different as it is powering incandescent light bulbs as well as standard Fluorescent bulbs. Similar principle of HV EM induction.
Sorry but you CAN'T BURN electrons.. all free systems uses spark gap, that is one key the other are resonance antenna coils used as energy amplifier. Tesla initially use simple the capacitor discharge using gap for light lamps directly.. you have to see tesla patent 462,418.Originally posted by cosmo-lv View PostThis coil and setup is designed to Burn electrons, in that kind of setup all electrons are Dead in Load.
The purpose of free energy is to make to electrons to Born and not to let to Die.
Lets look on one misinformation about ionization for combustion engines.
The ionization is not make sense - all sense are in High currents and these currents synchronization with ignition coil.
You say: "these both are not connected together!" yes they not, but the field where new electrons are created is big and this field resonates with ignition coil and other electric parts - this is different resonance.
If you not believe you can make test with spark gap and wire - if you play around with your car and HV transformer - you then MAYBE understand the phenomena of Borning electrons. More electrons Born then more the effect and more possibilities to make Free energy.
But if you burning these electrons in Load, then you cannot reach the Low of physic.
i personally don't need such of tests, i just see how its happening and i don't go deep to Esoteric things, but this is the way how its happening.
I suppose that radiant energy is in fact an highly static field formed from free electrons irradiation from point A/B of GAP. that energy is captured using copper for create ONLY negative field (see Gray tube).
In that way is possible build an simple battery/capacitor, with positive/negative sides using right metals and dielectric, for create electricity directly from radiant field.Last edited by tutanka; 09-24-2010, 07:17 PM.
counsciesness
here is a good reference to show why humanity dont have rised yet...
why dont let everybody be who they are, or do what they want? why is that such a big problem for you guys?
what i see... is that all of you want everybody to be like yourselfs, or like you want them to be!
everybody is free to do what they want... if you dont like it, dont look at it, whats dificult on doing that?
your freedom ends where the other one freedom begins!
i am nobody to play god, but... why if something is different from what you expect the firsts steps are make fun, ridicule, banish... like if you were the owners of the place or the judges!
why are you all so sure that he is not saying the truth or is not right?
from what I saw until now he only have good intentions and want to share ... the fact is everyone already rejected him from the first moment!
just because someone dont do what you want or dont think like you, does not give you the right to make fun or criticize! worst, to speak for all others!
